8 3/4 howl #1300379
09/09/12 12:20 PM
09/09/12 12:20 PM
dark side of the moon
Dougsmopars Offline OP
seems fine as long as your foot is on the gas, no noise, When you let off the gas and coast it has a howl. Any ideas? What to check?
Re: 8 3/4 howl [Re: Dougsmopars] #1300380
09/09/12 01:25 PM
09/09/12 01:25 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Howl is usually related to ring gear backlash, but often once it develops it can't be adjusted away.
Did it suddenly START doing this?
Re: 8 3/4 howl [Re: Pacnorthcuda] #1300381
09/09/12 01:30 PM
09/09/12 01:30 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
Get another rear. The rear side of the teeth on your ring gear are worn due to an incorrect contact pattern and you are unlikely to be able to adjust the howl out of it. Did you buy it that way it is it a new setup?
Re: 8 3/4 howl [Re: RoadRunnerJD] #1300382
09/09/12 09:25 PM
09/09/12 09:25 PM
Bought the car that way. Haven't tried any adjustments. Wondered if to much play in pinon
Re: 8 3/4 howl [Re: Dougsmopars] #1300383
09/10/12 09:25 AM
09/10/12 09:25 AM
Endicott, NY, USA
crazyjjk Offline
crazyjjk  Offline
Endicott, NY, USA
Low amount of gear oil will cause this also. Make sure case is full of gear oil.
Re: 8 3/4 howl [Re: crazyjjk] #1300384
09/10/12 10:19 AM
09/10/12 10:19 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Like said above - once a howl develops no amount of adjusting will correct it. either get a different set of gears or live with it. Some times some thicker lube will help some. Gear noise like you discribe will let you live a long time.
Re: 8 3/4 howl [Re: MoparforLife] #1300385
09/10/12 10:38 AM
09/10/12 10:38 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Like said , once it howls chances are it's always going to.
And some manufactures gears howl no matter how they're setup
Re: 8 3/4 howl [Re: Dougsmopars] #1300386
09/10/12 02:23 PM
09/10/12 02:23 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Pull it...Do an inspection...End the speculation...
Re: 8 3/4 howl [Re: RSNOMO] #1300387
09/10/12 07:46 PM
09/10/12 07:46 PM
God's Country Maryland
GODSCOUNTRY340 Offline
A loose pinion nut will also cause this noise. Drop the driveshaft and make sure the pinion nut is tight. While you're under there grab the yoke and see if there's any up & down movement, there should be none.
