Big Block with a Fluidampr Pulley Alignment ????? #1297944
09/05/12 02:05 PM
09/05/12 02:05 PM
Frederick, MD
moparguy1967 Offline OP
Frederick, MD
Im looking for a little help on getting my pulleys to line up correctly. I have a 440 with a Fluidampr installed on it. I've never had a motor with anything but a stock balancer on it. My motor is being finished up this week, and now im concerned my pulleys will not line up. Im currently running a 2 groove crank pulley, single groove alternator and power pump pulley. What do I need to do to make this set up work.
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: moparguy1967] #1297945
09/05/12 02:54 PM
09/05/12 02:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
another balancer .....
You will probably want to start with a 69 - 71 hemi lower pulley and go from there, once you wake up after pricing them you'll see the ... another balancer ... option is the better choice .
That said I had a fluidampner but it had a recessed face and worked with stock B/RB pulleys .
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: moparguy1967] #1297946
09/05/12 03:48 PM
09/05/12 03:48 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
Check and see what's the p/n of the Fluidampr. I believe the one I used is p/n 712425 which was not recessed. The newer FD #720311 appears to be recessed and may work with your existing pulleys. IIRC the hemi pulleys work with the non-recessed FD but don't quote me.
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: moparguy1967] #1297947
09/05/12 08:27 PM
09/05/12 08:27 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
you might look at these http://marchperf.com/pg45.html or http://marchperf.com/pg46.html
I used the small block set for a fluidamper before.(never used one on a big block) You can buy the pulleys seperately but they don't list them on their web page.
"Just a Bracket car dressed up like a streetcar"
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: moparguy1967] #1297948
09/07/12 09:32 AM
09/07/12 09:32 AM
NY
Fluidampr1 Offline
Fluidampr1  Offline
NY
Hi my name is Ivan and I work for Fluidampr. This damper is 20+ years old and was designed for a particular race application. As stated, we do offer a newer design with a recessed face and should work with your pulley configuration.
Since you have the old version, we are offering the opportunity to receive the new version at a discounted price. Please email me at ivan.snyder@fluidampr.com or call 716-592-1000 and ask for Ivan.
The following is a customer drawing which gives key dimensions and will allow you to determine if it is correct for your application.
http://i895.photobucket.com/albums/ac155/kalipbean/720311-C.jpg
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: Fluidampr1] #1297949
09/07/12 10:32 AM
09/07/12 10:32 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Now that is customer service
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: Fluidampr1] #1297950
09/07/12 07:56 PM
09/07/12 07:56 PM
Frederick, MD
Frederick, MD
email sent......
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: moparguy1967] #1297951
09/07/12 09:15 PM
09/07/12 09:15 PM
Wi.
old_racer Offline
old_racer  Offline
Wi.
now what are the chances of a Moparts member working for Fluidampr? pretty awesome!!!
thanks Ivan for chiming in. I have one of your dampers on one of my motors also.
Russ
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: old_racer] #1297952
09/07/12 09:22 PM
09/07/12 09:22 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I bought the flat faced fluidampr last winter from a gentleman after I already bought pullies and found out the same thing. Lucked out and found a march pulley from another guy on eBay.
Mopar to the bone!!!
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: 72Swinger] #1297953
09/10/12 11:45 AM
09/10/12 11:45 AM
NY
Fluidampr1 Offline
Fluidampr1  Offline
NY
Hi Guys and maybe Gals,
I have received emails and private messages from a few of you. I beleive I responded to all with details on exchanging the old style Mopar Fluidampr for the new version with recessed face.
If I missed anyone or you would like information about this or you have any questions about Fluidampr product, again, please feel free to email me ivan.snyder@fluidampr.com or call 716-592-1000 and ask for Ivan.
Thanks!
Ivan
Re: Big Block with a Fluidampr Pulley Alignment ????? [Re: Fluidampr1] #1297954
09/10/12 06:40 PM
09/10/12 06:40 PM
Frederick, MD
Frederick, MD
Thanks!
Ivan
Thank you
