Pentastar Location #1297029
09/04/12 09:28 AM
09/04/12 09:28 AM
North Carolina
Mikeymopar68 Offline OP
North Carolina
Does any one know the measurements to place the Pentastar on the right lower fender for a 68 Charger? The old fender was was removed and did not have the original holes in it for some reason and I want the resto to be as accurate as possible. My service manual does not give any measurements for the location either. Thanks
Re: Pentastar Location [Re: Mikeymopar68] #1297030
09/05/12 01:04 AM
09/05/12 01:04 AM
Sonoran desert, Arizona, USA
moparjo68 Offline
moparjo68  Offline
Here are pics of the location of the pentastar on my '68 Charger. The first pic, I am measuring from left lip of fender to the right.
Re: Pentastar Location [Re: moparjo68] #1297031
09/05/12 01:22 AM
09/05/12 01:22 AM
moparjo68 Offline
moparjo68  Offline
second pic is measuring from top lip of aluminum strip.
Re: Pentastar Location [Re: moparjo68] #1297032
09/05/12 01:24 AM
09/05/12 01:24 AM
moparjo68 Offline
moparjo68  Offline
Third pic is from right lip of fender going left.
Re: Pentastar Location [Re: moparjo68] #1297033
09/05/12 01:27 AM
09/05/12 01:27 AM
moparjo68 Offline
moparjo68  Offline
fourth pic is close-up shot measurement from right lip going left.
Re: Pentastar Location [Re: moparjo68] #1297034
09/08/12 03:15 PM
09/08/12 03:15 PM
North Carolina
North Carolina
Thank you MoarJo I really appreciate the help!
Re: Pentastar Location [Re: Mikeymopar68] #1297035
09/09/12 09:07 PM
09/09/12 09:07 PM
moparjo68 Offline
moparjo68  Offline
I got to thinking..........if you don't have a lower aluminum strip, you can't measure up from the strip then. If so, I could measure up from bottom of fender. Let me know. Joe
Re: Pentastar Location [Re: moparjo68] #1297036
09/09/12 09:32 PM
09/09/12 09:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Just for whatever it may be worth......
I measured three original 1970 Challenger fender pentastar locations once. They varied quite a bit, but all were within an inch up & down & side to side.
Also, some replacement fenders were not punched for the emblems.
