A63 / SE / Hood Trim - 1970 Challenger #1296480
09/03/12 09:39 PM
09/03/12 09:39 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I purchased a set of rear of fender and rear of hood stainless trim from a fellow member here for a 1970 Challenger R/T SE that I am finishing up. When I went to install them the fender pieces went on perfect but the hood piece seems to be just a tad long on both sides. It looks identical to another R/T SE that I have in the garage, but it's just a little long. Did any other car's run a similar Stainless rear of hood piece that would have been just a tad longer than a Challenger?
Thanks,
Paul
Re: A63 / SE / Hood Trim - 1970 Challenger [Re: faud88] #1296481
09/04/12 03:45 AM
09/04/12 03:45 AM
North America
2002bluert Offline
2002bluert  Offline
North America
Measure the one you have and I will measure the two I have on cars.
Re: A63 / SE / Hood Trim - 1970 Challenger [Re: 2002bluert] #1296482
09/04/12 03:22 PM
09/04/12 03:22 PM
Bel Air Maryland USA 21014
wmwalden Offline
wmwalden  Offline
Sounds like you have a moulding that goes on a Charger. The Challenger moulding is shorter then Charger. I have both. And have bought a Charger moulding that was sold as Challenger. The guy did take the part back and a full refund.
Re: A63 / SE / Hood Trim - 1970 Challenger [Re: faud88] #1296483
09/04/12 10:30 PM
09/04/12 10:30 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
I will have to measure mine. I didn't realize that there was a Charger version that looked so similar. What year Chargers did they use them on?
Re: A63 / SE / Hood Trim - 1970 Challenger [Re: faud88] #1296484
09/06/12 02:05 PM
09/06/12 02:05 PM
wmwalden Offline
wmwalden  Offline
I have seen them on 71 Chargers. Not sure of other years. I have full sets for both cars. Charger and Challengers. The back of the hood, fenders, down the doors and the rear side window.
And actually the back fender pcs for Charger are slightly different from Challenger. When you see both held together is the only time you can see the deference.
