Page 5 of 6 1 2 3 4 5 6
Re: 71RR V code project [Re: gygeneral] #1295195
11/26/13 09:37 PM
11/26/13 09:37 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
The best part of the car...........
Re: 71RR V code project [Re: gygeneral] #1295196
11/27/13 11:25 AM
11/27/13 11:25 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Agreed
Car looks AWESOME
Re: 71RR V code project [Re: gygeneral] #1295197
11/27/13 03:25 PM
11/27/13 03:25 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Is that 'long arm' original to the car???
Re: 71RR V code project [Re: RSNOMO] #1295198
11/27/13 07:20 PM
11/27/13 07:20 PM
Ont, Canada
Ont, Canada
Yes it is, what your looking at is a new one, but my original stick is hanging on the wall.
Re: 71RR V code project [Re: gygeneral] #1295199
12/02/13 07:35 PM
12/02/13 07:35 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Bench-seat cars got the 'long' shifter???
Drove one '71 V-code RR...
Had the 'short' Pistol-Grip...
Don't remember if it had buckets...
Re: 71RR V code project [Re: RSNOMO] #1295200
12/02/13 08:00 PM
12/02/13 08:00 PM
Ont, Canada
Ont, Canada
Cars with buckets with console had the short one. It used a different mounting points on the transmission.
Re: 71RR V code project [Re: RSNOMO] #1295201
12/02/13 08:01 PM
12/02/13 08:01 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
and a different shift boot.
Re: 71RR V code project [Re: gygeneral] #1295202
12/16/13 09:34 PM
12/16/13 09:34 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
71 bench seat and buckets with buddy seat use a medium pistol grip and a short tunnel
Buckets seats with a console or not uses a short pistol grip and same tunnel as a E-body
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 71RR V code project [Re: 440beep] #1295203
12/16/13 09:42 PM
12/16/13 09:42 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
short tunnel
Re: 71RR V code project [Re: 440beep] #1295204
12/16/13 09:45 PM
12/16/13 09:45 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
Re: 71RR V code project [Re: 440beep] #1295205
04/02/15 03:33 PM
04/02/15 03:33 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Any updates on this one?
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 71RR V code project [Re: 70440+6bbl] #1295206
04/04/15 09:05 PM
04/04/15 09:05 PM
Ont, Canada
Ont, Canada
Thanks for asking. After I finished assembling the car last July, when it came time to start it, it would not run correctly. In the end I had to have the carbs completely rebuilt again over the winter. This has put me back almost a year. I had to wait for the right guy to fix the work the original guy did. Basically the carbs looked good but they were not functional. Then the car got stuck in the guy's garage because of the snow last winter. I just got it back home last week. Hoping to get it finished onver the next couple months. Anyhow here are some pictures after assembly last year. I have to get the car aligned, put the stripes/decals on and undercoat the wheelwells.
Re: 71RR V code project [Re: gygeneral] #1295207
04/04/15 09:11 PM
04/04/15 09:11 PM
Ont, Canada
Ont, Canada
last summer
Re: 71RR V code project [Re: gygeneral] #1295208
04/04/15 09:29 PM
04/04/15 09:29 PM
Ont, Canada
Ont, Canada
engine
Re: 71RR V code project [Re: gygeneral] #1295209
04/04/15 09:50 PM
04/04/15 09:50 PM
Ont, Canada
Ont, Canada
link to hear it running
http://youtu.be/_JyvrPT2Dr4
Re: 71RR V code project [Re: gygeneral] #1797328
04/07/15 01:18 PM
04/07/15 01:18 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
Can you post up pictures of your detailed front suspension??
Car is looking excellent!
Ron
Re: 71RR V code project [Re: RJS] #1797361
04/07/15 01:50 PM
04/07/15 01:50 PM
Ont, Canada
Ont, Canada
If you need anything specific just ask I will try and answer your question.
Re: 71RR V code project [Re: gygeneral] #1797493
04/07/15 03:46 PM
04/07/15 03:46 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
By those pictures I'm in the ballpark, I was going to have the disc shields powder coated Gloss Black or is Low Gloss more correct?
Also where did you get the anti rattle clips and hardware?
I have to order calipers and the clips next.
I'm going to Black Phosphate the bolts for the sliders etc...
Lastly the idler arm I took off (it wasn't original but super old) had a curve to it but the new Moog K7041 was straight and thought that was strange. Mine is a Power Steering car.
Thanks Ron
Re: 71RR V code project [Re: gygeneral] #1797523
04/07/15 04:09 PM
04/07/15 04:09 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Ron, I matched what original paint was still left on my dust shields to the samples the powder had on hand. It was a low gloss black. Probably was low quality gloss when new, but that's a tough environment. All of the lower control arms I have owned (including NOS), the cosmolene dipline is closer to the top rivet. Either way, nice job! And GYgeneral, your runner is looking great!
Re: 71RR V code project [Re: 70440+6bbl] #1797788
04/07/15 08:35 PM
04/07/15 08:35 PM
JERSEY
RJS Online work
RJS  Online Work
JERSEY
I have a picture saved from years ago with the dip line like I have it so I always followed that, if you were a day sooner I would have moved it up!!! OK so low Gloss Black it will be, I sent you a PM before and after the board changes did you get either??
What about my idler arm question can you or GYgeneral answer that for me?
Thanks again
Ron
