Comp Cams 10* Super Locs #1293931
08/29/12 08:43 PM
08/29/12 08:43 PM
Belpre,Ohio
CHAPPER Offline OP
CHAPPER  Offline OP
Belpre,Ohio
Looking for a better loc than their's. I have had 4 failures with them in the past 2 years. Most were caught before any major damage,,ONE wasn't.!!..guess whose engine that ONE was on??
It appears that some of the locs are soft, as in not getting the heat treat that the others are getting. It is not a complete set that is wearing and pulling through, just one on an entire engine.
If you like drag racing, support your local track.
Re: Comp Cams 10* Super Locs [Re: CHAPPER] #1293932
08/29/12 09:40 PM
08/29/12 09:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
ISKY.................
Re: Comp Cams 10* Super Locs [Re: Thumperdart] #1293933
08/29/12 10:13 PM
08/29/12 10:13 PM
Newfoundland,Canada
avenger572 Offline
avenger572  Offline
Newfoundland,Canada
Sounds like not enough seat spring presure. Valves are bouncing when they close and wearing the lock grooves.
Re: Comp Cams 10* Super Locs [Re: CHAPPER] #1293934
08/29/12 10:22 PM
08/29/12 10:22 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
the 10° came about because of instances of the 7° pulling through. i've used 10s without incident but one thing i can say is that there's always been a burr on the valve lock groove upon disassembly, the 10s simply don't wedge as tight due to the angle. afaik the super 7s are the best setup going these days. imho before condemning the locks make sure there aren't other valvetrain issues. i'm willing to bet when it comes to parts such as locks, springs, retainers etc. there aren't a lot of different manufactures making them. most are probably coming from the same (few) sources then labeled by the sellers as their own so don't think just because you buy them from a different company you're getting a different part. 2¢
Re: Comp Cams 10* Super Locs [Re: jamesc] #1293935
08/29/12 11:45 PM
08/29/12 11:45 PM
Az
Crizila Offline
Crizila  Offline
Az
Agree on the super 7's single round grove being the best thing going. Hughes sells them, but I don't know who makes them.
Fastest 300
Re: Comp Cams 10* Super Locs [Re: Crizila] #1293936
08/30/12 12:12 AM
08/30/12 12:12 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
We use the Comp 10 degree on most of our engines thst use a shelf stock valve with square grooves,no failures with thousands of runs logged.We use Bead Loc@ radius grooves 10 degree when we order custom valves,and again no failures.Bill C.
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
Re: Comp Cams 10* Super Locs [Re: BIGSPEED] #1293937
08/30/12 07:05 AM
08/30/12 07:05 AM
Washington
skrews Offline
skrews  Offline
Washington
Crower or Manley nothing better. Comp 10* aren't even machined at a true 10*, and quality is hit or miss at times with those guys.
Re: Comp Cams 10* Super Locs [Re: skrews] #1293938
08/30/12 08:27 AM
08/30/12 08:27 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I haven't seen any ten degree failures from the lock failing. That being said, my brain still likes the increased stem clamping a 7, or super 7 provides. I understand it puts more load on the retainer by making the wedge tighter like an axe, but I like the thought of that better. Just personal weirdness.
Re: Comp Cams 10* Super Locs [Re: dthemi] #1293939
08/30/12 09:44 AM
08/30/12 09:44 AM
tboomer Offline
tboomer  Offline
Interesting discussion...When Radar put my MP aluminum heads together,he used all Manley hardware..I think we will use the Manley stuff on the new Victors...
Re: Comp Cams 10* Super Locs [Re: tboomer] #1293940
08/30/12 06:03 PM
08/30/12 06:03 PM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
Comp and Manley come off the same machines.Bill C.
Re: Comp Cams 10* Super Locs [Re: BIGSPEED] #1293941
08/31/12 01:13 AM
08/31/12 01:13 AM
New York, USA
Chargerfan68 Offline
New York, USA
I was assembling my motor with the Comp 10 deg. and did not like the fit at all. I replace both the locks and retainers with Isky 10 deg. and the fit was much much better.
I have the comps on the shelf, where they will probably forever sit.
