neon engine interchange question #1293847
08/29/12 07:20 PM
08/29/12 07:20 PM
st louis mo
Q5Bee B5ScatPack Offline OP
st louis mo
I have a 1996 neon 2.0 sohc with LOTS of miles,i can buy a complete wrecked 2004 neon with low miles for cheap,question is,will the 2004 powerplant interchange into my 1996?
1969 SUPERBEE 383 Q5 RED STRIPE WHITE INT.
2015 CHALLENGER SCAT PACK B5 BLUE
1996 INDY RAM PACE TRUCK
Re: neon engine interchange question [Re: Q5Bee B5ScatPack] #1293848
08/29/12 09:56 PM
08/29/12 09:56 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I know for sure that the intake manifolds are different, The 96 will have EGR and the 04 likely will not. otherwise should work.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: neon engine interchange question [Re: 71yelladustr] #1293849
08/29/12 10:41 PM
08/29/12 10:41 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My Daily driver is a 95 Neon 2.0L DOHC. When I bought it I was told they had paid to have a 99 2.0L DOHC swapped in it place with 45,000 less miles on it. Sorry, but I don't know how much or if any of the 04 is inter-changeable or not.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: neon engine interchange question [Re: 6PKRTSE] #1293850
08/30/12 12:02 AM
08/30/12 12:02 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Not sure on the cars, but I know for 1997 on the trucks and jeeps ALL the sensor connectors changed. So you at a minimum would need to retain those from your old engine.
Re: neon engine interchange question [Re: DaytonaTurbo] #1293851
08/30/12 01:13 AM
08/30/12 01:13 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Sorry, they will not enterchange. The 2004 is a NGC motor. They use different electronics and will not swap with earlier cars. You will need to look for a motor that is atleast 2001 or older. First gens are getting scarce since the circle track guys have been snapping them up and killing them.
Re: neon engine interchange question [Re: rallye73] #1293852
08/30/12 09:53 AM
08/30/12 09:53 AM
western new york
horsepower.2007 Offline
western new york
Crank sensor location is different
Re: neon engine interchange question [Re: horsepower.2007] #1293853
09/01/12 11:20 AM
09/01/12 11:20 AM
st louis mo
st louis mo
