what would you do??
#129190
09/28/08 08:15 PM
09/28/08 08:15 PM
Posts: 3,753 Gulf Coast of Florida
Russ
super gas
super gas
I have an 86 Aries with only 38.000 miles,when i bought it about 6 months ago It had 32.000 miles,the original motor blew up at 36.000 miles,i put in a good motor with 84.000 miles,and everything was fine till today,It will not hold coolant,and It Is going somewhere,not out the exhaust,the oil looks good(nothing milky) and nothing on the driveway,but everytime i drive it now the temp guage goes up to the max,then comes down,i replaces the thermostat,and coolant temp switch again,but after It cools down,the radiator Is 1/2 empty,and the overflow Is only 1/2 full,but i see bubbles in the overflow after about 15 minutes of idling. any ideas? ![](/ubbthreads/images/graemlins/beer.gif)
2001 Durango 5.9 Magnum
99 Durango 5.9 Magnum
Parting out 99 Durango 5.9,99 Ram 1500 and 98 Ram 1500 5.9
WANTED.Ram Truck,Durango/Dakota parts and parts trucks!!PM Me.
GO BUCKS!!!!
Go GATORS!!!!
Re: what would you do??
[Re: Russ]
#129191
09/28/08 08:24 PM
09/28/08 08:24 PM
Posts: 317 Indiana
79_W200
Indiana
could be head gasket - check spark plugs
1979 W200 470
[Re: 79_W200]
#129193
09/28/08 09:17 PM
09/28/08 09:17 PM
Russ
super gas
super gas
all the plugs look like new,I replaced them when the motor was installed
This Is the same thing that happened with the original motor,at least this one still runs for now,the car Is like new,inside and out,but but I have over $1.500 in It now!book value is $900.00 per KBB I was going to scrap It last time(I was very %^$& at It then),but found the other 86 Aries for the motor,but my car Is too nice to dump Into a scrap yard,but i'm sure nobody will ever want it,so what should i do?????
GO BUCKS!!!!
Go GATORS!!!!
[Re: Russ]
#129194
09/28/08 09:41 PM
09/28/08 09:41 PM
Russ
super gas
super gas
Here's a couple of pics right after I bought it,Still has the original paint/clearcoat,always garaged too.
looks even better now,after a lot of cleaning
GO BUCKS!!!!
Go GATORS!!!!
[Re: Russ]
#129197
09/29/08 08:05 AM
09/29/08 08:05 AM
If the motor was replaced recently and you are finding "no" coolant leaking or blowing out the tail pipe, it might be possible you have an air pocket in the coolant system including the heater core. Before pulling the head, maybe try to bypass the heater core, check the core for blockage, verify no heater hoses are vise versa etc. Also, not knowing the H2O pumps condition you may want to toss one in to rule that out. Who knows, if the pump was on the engine and it sat for a period of time, the fins may be deteriated and can't blow the system to specs. Good luck !! ![](/ubbthreads/images/graemlins/Twocents.gif)
#129199
09/29/08 09:05 AM
09/29/08 09:05 AM
Russ
super gas
super gas
did all that too,if this ceramic stuff doesn't work,i'll probably take It to a swap meet that's going on this weekend,and sell It with a notation that It has a cooling system problem ![](/ubbthreads/images/graemlins/down.gif)
GO BUCKS!!!!
Go GATORS!!!!
[Re: Russ]
#129200
09/29/08 02:43 PM
09/29/08 02:43 PM
Russ
super gas
super gas
A friend of mine said to drain the cooling system,flush It good,fill It back with just water,then ad a jar of liquid glass,and let It run for an hr and let It set for 24hrs,then drain and refill with coolant ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Said he did that with a slant 6,and was good for 3 years
GO BUCKS!!!!
Go GATORS!!!!
[Re: badblack68]
#129206
09/30/08 09:17 PM
09/30/08 09:17 PM
Russ
super gas
super gas
Ok Mark Put a new radiator and cap in it,bled It too,and a fan switch,drove it over 150 miles today without no problems,go figure ![](/ubbthreads/images/graemlins/thumbs.gif) Didn't put the liquid glass In It either ![](/ubbthreads/images/graemlins/thumbs.gif) Never went above 190 degrees on the guage with the A/C going.And It was 88 here today The old radiator was seeping out the bottom,and full of red goop,flushed It all out,new radiator/cap,etc,good to go so far ![](/ubbthreads/images/graemlins/thumbs.gif) I think It's fixed ![](/ubbthreads/images/graemlins/thumbs.gif)
GO BUCKS!!!!
Go GATORS!!!!
