Valve spring installed height ?? #1291441
08/26/12 12:57 AM
08/26/12 12:57 AM
Mooresburg, Tn
'72CudaRacer Offline OP
Mooresburg, Tn
How much leway is allowable to the valve spring installed height? My springs call for an installed height of 1.900". I have several that are less than that by .003"-.006", and most are above 1.900" by the same amount. Shims start at .015", so I'm guessing that inside that number will be an acceptable tolerance? I do have one that needs a .015" shim to bring it to +.006".
Also, how close to coil bind can the springs be and still be safe?
Thanks,
Brian Dunnigan
Re: Valve spring installed height ?? [Re: '72CudaRacer] #1291442
08/26/12 02:47 AM
08/26/12 02:47 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I was in the same boat needing 1.900 but was a bit shy and we made it work and I`m at about .060 from coil bind at a true .660 lift.
Re: Valve spring installed height ?? [Re: Thumperdart] #1291443
08/26/12 05:10 AM
08/26/12 05:10 AM
Washington
skrews Offline
skrews  Offline
Washington
I shoot for .010 + or -. Running the springs as close to coil bind with out coming to close will cancel out a lot of spring surge and harmonics.
Re: Valve spring installed height ?? [Re: '72CudaRacer] #1291444
08/26/12 02:22 PM
08/26/12 02:22 PM
I don't go by installed heghts,, I have a spring tester and I set them up with shims as needed so I have .060 to .080 from coil bind at full lift You will need to check your lift at the retainers after that to insure you don't have a roque rocker that has more ratio than it takes to coil bind your springs I write down each installed hieght with the shims and check all the valve lifts at the retainers I usually end up with less lift at the retainer than the cam should open the valves, deflection and bending of parts does that I have had rockers that make more lift than advertised as well as less lift
Re: Valve spring installed height ?? [Re: Cab_Burge] #1291445
08/27/12 01:41 AM
08/27/12 01:41 AM
NEW JERSEY
BIGSPEED Offline
BIGSPEED  Offline
NEW JERSEY
X2
Ceralli Racing Engines & Checkered Flag Machine Racing engines , CNC porting & induction development http://www.checkeredflagmachine.net/
