Re: 5.9 magnum engine
[Re: d-150]
#1290543
08/25/12 04:07 AM
08/25/12 04:07 AM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
use the stock Magnum flexplate there will one hole that will not fit the torque converter by 1/8" open this hole to fit the Magnum uses a neutral balance converter 96-up You can run a mechanical fuel pump usibypassng the older Vbelt stuff & a cam extension kit from Hughes Racing Using a Professional Products Crosswinds intake will allow you to use all V belt accessories 78 & back including the correct bypass hose for the waterpump
[Re: Clayton]
#1290544
08/26/12 01:46 AM
08/26/12 01:46 AM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
You'll be very happy with the swap...great performance from a very very mild engine. A member here swapped one in my LRT prior to me purchasing it...pulled down around 17mpg on the hwy, reasonably quick (15.1 @ 91 w/ a race wt north of 4100lbs through '79 log manifolds), pulled 23" of vacuum. Not many (any?) better alternatives out there in my opinion for the price.
1979 Dodge Lil' Red Express - 360 rwhp, 13.2 @ 103mph 1968 Coronet: 318, 2.76, 15.2 @ 92mph! (SOLD) 1976 Valiant: 360, 3.90, 12.90 @ 106 (SOLD) 1989 Shelby CSX #500/500
[Re: Clayton]
#1290545
08/26/12 08:28 AM
08/26/12 08:28 AM
Posts: 377 Michigan Troll
blk00rt
Michigan Troll
I think on the 2001 or 2002 and later blocks they removed the A engine mounting ears on the front of the engine.
Rob Dunn 1976 Dart Sport 360 2000 dakota RT 408 with 150 nitrous 2013 Dodge Ram 1500 Hemi 2009 Jeep Patriot
