What to put between gas tank and floor? #128959
09/28/08 02:04 PM
09/28/08 02:04 PM
Akron,Ohio
gkgeiger Offline OP
mopar addict
gkgeiger  Offline OP
mopar addict
Akron,Ohio
What have you used?
Re: What to put between gas tank and floor? [Re: gkgeiger] #128960
09/28/08 02:14 PM
09/28/08 02:14 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
I know what this is all about...I've seen the repop piece that looks more like foam than the tar type material originally used... I'm contemplating the same question for a project I'm working on now....I was thinking about using the thickest roofing felt paper I could find...That's seems to be an asphalt/tar type material...
Re: What to put between gas tank and floor? [Re: screamindriver] #128961
09/28/08 02:32 PM
09/28/08 02:32 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Keep in mind that the gas tank sweats. The water produced is trapped between the insulator and the tank. You need something that will absorb the water and keep the tank dry. I don't think the reproduction pads will do this.
Hear is a comparison picture of the original tank pad material and felt roofing paper. They are about the same thickness.
The original has grooves and the felt doesn't. The grooves could be there to help channel the water build up away from the tank and allow ventilation to help prevent rusting.
Re: What to put between gas tank and floor? [Re: gkgeiger] #128962
09/28/08 02:39 PM
09/28/08 02:39 PM
Puyallup, Wa.
Steve340 Offline
Steve340  Offline
Puyallup, Wa.
I used the thickess felt roofing paper that Home Depot had and it was almost an exact match to the original. That aftermarket foam tank insulator pad is a joke.
Re: What to put between gas tank and floor? [Re: Snoopy] #128963
09/28/08 02:39 PM
09/28/08 02:39 PM
Akron,Ohio
gkgeiger Offline OP
mopar addict
gkgeiger  Offline OP
mopar addict
Akron,Ohio
I just had a thought. What would you think of using Dynamat
Re: What to put between gas tank and floor? [Re: gkgeiger] #128964
09/28/08 05:46 PM
09/28/08 05:46 PM
Burma Shave
plymouthfan Offline
plymouthfan  Offline
Burma Shave
Someone stuck some rubber floor mats over mine It's all coming out this winter anyway...
One red car, one yellow car.
Re: What to put between gas tank and floor? [Re: gkgeiger] #128965
09/28/08 09:46 PM
09/28/08 09:46 PM
Virginia, US
RTDaddy Offline
super street
RTDaddy  Offline
super street
Virginia, US
I use strips of conveyor belt material, about 1/8" to 1/4" thick, just where the floor braces are. Don't like the idea of the matt that holds moisture. Just my $0.02.
"IF YOU'RE UNDER CONTROL, YOU AIN'T GOING FAST ENOUGH."
Re: What to put between gas tank and floor? [Re: RTDaddy] #128966
09/29/08 11:38 AM
09/29/08 11:38 AM
Central Ky, area
CHRYCOFAN Offline
CHRYCOFAN  Offline
Central Ky, area
I've been going down to the local ACE Hardware & buying the Rubber "Runner mat". Black rubber with ribs on one side. @ 2 ft wide & I get it as long as needed. Use the old mat as a template & cut it to fit.
Like everybody else has said I figure the ribs would help with condensation.
Butch
