No brake lights #1289065
08/21/12 10:22 AM
08/21/12 10:22 AM
NE
O
Oldstrtracr Offline OP
O
NE
Need help please. No brake lights, tail lights work, left side hazard works, right side very faint, turn signal left side works, (right side turn signal no) new brake switch in last nite. 1970 Challenger R/T. This does have cruise control, could the wiring for cruise affect brake lights? Also new paint, should i check ground in back. Thanks Moparts.
Re: No brake lights [Re: Oldstrtracr] #1289066
08/21/12 10:34 AM
08/21/12 10:34 AM
Watertown, WI
MikeyT Offline
MikeyT  Offline
Watertown, WI
Check grounds in back, also I know silly, but the fuse?
Mike
1969 Dodge Dart Swinger
Re: No brake lights [Re: MikeyT] #1289067
08/21/12 10:56 AM
08/21/12 10:56 AM
NE
O
O
NE
Checked fuses, all ok. Thanks
Re: No brake lights [Re: Oldstrtracr] #1289068
08/21/12 03:09 PM
08/21/12 03:09 PM
seperate the turn signal electrical connector under the steering column & with your VOM and the TS stalk in nuetral see if there is continuity between the "in" wire from the brake light switch (it's white) & the 2 "out" wires to the left/right rear brake lights (turn signals/brakes/hazards use the same single large filament in the 1157 dual filament bulbs) & taillights use the small filaments & that circuit originates seperately in the headlight switch. See if the right side bulb/socket has continuity to ground. If so go behind the drivers side kick panel & seperate the connector & see if the wire to the right rear large filament has continuity (The left side large filament does because the left TS works)
Re: No brake lights [Re: RapidRobert] #1289069
08/21/12 04:02 PM
08/21/12 04:02 PM
NE
O
O
NE
Thanks, will check when i get home tonite.
Re: No brake lights [Re: Oldstrtracr] #1289070
08/21/12 04:25 PM
08/21/12 04:25 PM
WV
JohnH Offline
JohnH  Offline
WV
good chance your turn signal switch is bad, the brake lights has to go thru it so it will make the signal work when the brakes are applied.. also cruise control will not affect it.
Re: No brake lights [Re: JohnH] #1289071
08/21/12 04:27 PM
08/21/12 04:27 PM
IL
furious70 Offline
furious70  Offline
IL
check the brake light switch on the pedal arm, they can come loose and not trigger the plunger.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: No brake lights [Re: Oldstrtracr] #1289072
08/21/12 05:34 PM
08/21/12 05:34 PM
Ohio USA
danspony Offline
danspony  Offline
Ohio USA
hi, no the cruse wont affect the brake lights the brake switch has a sepp. circuit just for that, test to see if you have bat, voltage to the brake switch if you dont it is most likely the turn sig switch , very comon prop.
Re: No brake lights [Re: danspony] #1289073
08/21/12 05:48 PM
08/21/12 05:48 PM
NE
O
O
NE
Put in new brake switch, yes there is power to switch, checked it twice to be sure. Thanks
Re: No brake lights [Re: Oldstrtracr] #1289074
08/21/12 05:55 PM
08/21/12 05:55 PM
TX , NJ , FL
W
WINGCARS_6970 Offline
W
TX , NJ , FL
Turn signal switch most likely.Brake switch has pink and white wires check for power .Or jumper the 2 together.Bypass brake switch
1969 Daytona 440 L9B410772 1970 Coronet 500 383 Presently owned 1970 Superbird 440 U 166242 1970 Superbird 440 U 174597 1970 Superbird 440-6 V 179697 1970 Coronet RT 440 U 224126 1968 Road Runner 426 J 134509 1970 Daytona Replica 318 G 178701
Re: No brake lights [Re: WINGCARS_6970] #1289075
08/21/12 06:50 PM
08/21/12 06:50 PM
Minnesota
Mad Accountant Offline
Minnesota
Dumb question i know, but did you check the bulbs? You should have two filaments on each. I recently blew the brake lights and when i checked the bulbs they seemed ok. But, both brake light filaments had completely burned off, including the posts, so they looked like single filament bulbs. I didn't know there were supposed to be two, so i spent a week checking wiring. My bad signals were due to a bad flasher, too.
Re: No brake lights [Re: RapidRobert] #1289076
08/23/12 09:54 AM
08/23/12 09:54 AM
NE
O
O
NE
Believe its the switch. Who sells good quality Turn Signal Switch? 1970 Challenger R/T Thanks Moparts
Re: No brake lights [Re: Oldstrtracr] #1289077
08/23/12 12:39 PM
08/23/12 12:39 PM
WV
JohnH Offline
JohnH  Offline
WV
Bought mine from year one
