Re: No brake lights
[Re: Oldstrtracr]
#1289068
08/21/12 04:09 PM
08/21/12 04:09 PM
RapidRobert
seperate the turn signal electrical connector under the steering column & with your VOM and the TS stalk in nuetral see if there is continuity between the "in" wire from the brake light switch (it's white) & the 2 "out" wires to the left/right rear brake lights (turn signals/brakes/hazards use the same single large filament in the 1157 dual filament bulbs) & taillights use the small filaments & that circuit originates seperately in the headlight switch. See if the right side bulb/socket has continuity to ground. If so go behind the drivers side kick panel & seperate the connector & see if the wire to the right rear large filament has continuity (The left side large filament does because the left TS works)
Re: No brake lights
[Re: Oldstrtracr]
#1289070
08/21/12 05:25 PM
08/21/12 05:25 PM
Posts: 549 WV
JohnH
WV
good chance your turn signal switch is bad, the brake lights has to go thru it so it will make the signal work when the brakes are applied.. also cruise control will not affect it.
Re: No brake lights
[Re: JohnH]
#1289071
08/21/12 05:27 PM
08/21/12 05:27 PM
Posts: 2,255 IL
furious70
IL
check the brake light switch on the pedal arm, they can come loose and not trigger the plunger.
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: No brake lights
[Re: Oldstrtracr]
#1289074
08/21/12 06:55 PM
08/21/12 06:55 PM
Posts: 7,595 TX , NJ , FL
WINGCARS_6970
TX , NJ , FL
Turn signal switch most likely.Brake switch has pink and white wires check for power .Or jumper the 2 together.Bypass brake switch
1969 Daytona 440 L9B410772
1970 Coronet 500 383 Presently owned
1970 Superbird 440 U 166242
1970 Superbird 440 U 174597
1970 Superbird 440-6 V 179697
1970 Coronet RT 440 U 224126
1968 Road Runner 426 J 134509
1970 Daytona Replica 318 G 178701
