SWOLLEN OIL FILTER #1288844
08/20/12 10:51 PM
08/20/12 10:51 PM
NEW HAMPSHIRE AND MAINE
BIGSTROKER Offline OP
had my road runner up on the lift yesterday and noticed my oil filter was all swollen it's a wix 51515 first time I ever saw that on my car haven't changed anything in years. whats up?
Re: SWOLLEN OIL FILTER [Re: BIGSTROKER] #1288845
08/20/12 10:52 PM
08/20/12 10:52 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Put it in the freezer and see if that helps?
Re: SWOLLEN OIL FILTER [Re: BIGSTROKER] #1288846
08/20/12 11:00 PM
08/20/12 11:00 PM
tn
robnbird Offline
robnbird  Offline
tn
I would say your pressure check valve in the oil pump stuck. take it out and clean it.
Re: SWOLLEN OIL FILTER [Re: robnbird] #1288847
08/20/12 11:06 PM
08/20/12 11:06 PM
thats a thought but i am always looking at that guage and never noticed anything, i'm wondering how long it's been like that
Re: SWOLLEN OIL FILTER [Re: robnbird] #1288848
08/20/12 11:25 PM
08/20/12 11:25 PM
Do it now before running the motor again They are real easy to remove, if it won't slide out easily it is probally galled up or it has a very small piece of trash(silicone,gasket material, metal debris or?) in it holding the valve stuck in the pump top and not letting it bypass I'm asuming this a BB Roadrunner and not a later SB one Either way it needs checking
Re: SWOLLEN OIL FILTER [Re: BIGSTROKER] #1288849
08/21/12 12:14 AM
08/21/12 12:14 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You may not have noticed it but its been over 100#
to do that..... check the relief valve/clean it
Re: SWOLLEN OIL FILTER [Re: MR_P_BODY] #1288850
08/21/12 12:23 AM
08/21/12 12:23 AM
Amherst,NY
challengermike Offline
Amherst,NY
Same thing happened to my wix filter. I put a used pump on mine started it and pressure was 125 at idle and then it spit out the oring. Also broke the gauge it stuck the needle straight down.
Re: SWOLLEN OIL FILTER [Re: challengermike] #1288851
08/21/12 01:10 AM
08/21/12 01:10 AM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
His is swollen and yours is broken and stuck straight down. Must be hell to get old.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: SWOLLEN OIL FILTER [Re: kilroy] #1288852
08/21/12 01:56 AM
08/21/12 01:56 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Too funny.............
Re: SWOLLEN OIL FILTER [Re: BIGSTROKER] #1288853
08/21/12 07:55 AM
08/21/12 07:55 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
My car has had problems pushing oil past the o-ring on WIX 51085 (NAPA Gold 1085) oil filters (small block A-body). I just switched to the K&N HP-2004 (it has a nut attached to the "bottom" of the filter body, this is pretty awesome because I know I got the filter tight putting it on and I know I will be able to remove it no problem). The K&N has a much better method for securing the o-ring and the case is .021" thick compared to the WIX which is .017" thick. I think it is time you switch brand of filter. I am hoping this K&N will satisfy my needs because it was expensive. Cold my car idles with 60lbs of pressure and 20lbs hot.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: SWOLLEN OIL FILTER [Re: bigsbigelow] #1288854
08/21/12 08:07 AM
08/21/12 08:07 AM
well i have tried the kn filter but i got case of the 51515's off the site and they get very little time between changes and never had a problem.
i have a case of the 51515r's which have a thicker case but i don't like useing them because the element is to corse. i will get to the bottom of this, it's not rocket science either the filter was thin which i doubt or i buzzed the motor before the oil was up to temp. or the it's valve like everybody seem to think
Re: SWOLLEN OIL FILTER [Re: BIGSTROKER] #1288855
08/21/12 11:04 PM
08/21/12 11:04 PM
Central NC
gch Offline
gch  Offline
Central NC
Cialis pill falls into oil thus you have a filter swollen for more than 4 hours.Seek immediate medical treatment.
Re: SWOLLEN OIL FILTER [Re: BIGSTROKER] #1288856
08/22/12 05:44 PM
08/22/12 05:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Uhhh, you're not allowed to mention filter problems here unless it's a Fram.
Re: SWOLLEN OIL FILTER [Re: kilroy] #1288857
08/22/12 07:15 PM
08/22/12 07:15 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Mine is old. It hasn't been swollen or stuck staight out for awhile. I'm thinking it might be broken.
If you like drag racing, support your local track.
Re: SWOLLEN OIL FILTER [Re: John_Kunkel] #1288858
08/22/12 07:30 PM
08/22/12 07:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its not a filter problem John... its a stuck by pass
problem.... any filter will blow given enough pressure
Re: SWOLLEN OIL FILTER [Re: MR_P_BODY] #1288859
08/22/12 07:34 PM
08/22/12 07:34 PM
ill
dennismopar73 Offline
ill
I have no issue , Run @ 85-90# pressure,, sounds as if it just bad filter?? but,,IDONO,, I run Fram so?? go figure!!
Re: SWOLLEN OIL FILTER [Re: gch] #1288860
08/22/12 07:35 PM
08/22/12 07:35 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Would that require medical or mechanical treatment
Re: SWOLLEN OIL FILTER [Re: dennismopar73] #1288861
08/22/12 07:45 PM
08/22/12 07:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think he had pressures in the range of 110-115
at high RPM
Re: SWOLLEN OIL FILTER [Re: BIGSTROKER] #1288862
08/22/12 08:45 PM
08/22/12 08:45 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
if its hot and swollen then it might be ready how often do you use it
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: SWOLLEN OIL FILTER [Re: WHITEDART] #1288863
08/22/12 10:40 PM
08/22/12 10:40 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
My wife handles all my oil filter problems... I think ILL keep her
