Re: Self destructing pully belts why? [Re: slantzilla] #1287671
08/19/12 07:18 PM
08/19/12 07:18 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Did they give you the right pitch belt for the pulleys? The fact that it's so deep in the pulleys and cupped leads me to believe it's the wrong belt.
That's what I'm thinking.
The top of the belt is too wide for the pulleys. When it comes to V belts, not all Vs are the same. The V on your pulleys seem to be a narrower angle than the belt. That means your belt was riding on the upper edges and not the full depth of the V.
- Stu Harmon
Re: Self destructing pully belts why? [Re: MidPenMopar] #1287672
08/19/12 11:12 PM
08/19/12 11:12 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I think that belt has been slipping for a while causing premature wear. Get a new one on there and see how it looks. Clutch fan and higher amp alternators will smoke a belt in a short time. Needs to be re-tightened after belt seats in.
Re: Self destructing pully belts why? [Re: NITROUSN] #1287673
08/19/12 11:40 PM
08/19/12 11:40 PM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
You may be right, but i do check the tightness of the belts each month or so.
I spent some time cleaning it up today as well.
Re: Self destructing pully belts why? [Re: NITROUSN] #1287674
08/21/12 09:11 PM
08/21/12 09:11 PM
Finally found the problem to be the bolt that holds the alternater bracket to the engine block had backed out and cut into the belt.
Thanks for the help guys!
Re: Self destructing pully belts why? [Re: idrivevintage] #1287675
08/22/12 09:29 AM
08/22/12 09:29 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
Look again, the long bolt that holds the alternator to the head could have backed out a bit and made contact with the belt...chewing it up
Thats happened to me before
Good luck...
Close...just the wrong bolt
Glad you found it, your Roadrunner looks great
Re: Self destructing pully belts why? [Re: feets] #1287676
08/22/12 10:10 AM
08/22/12 10:10 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I would still look at this too. Nice car! Glad you found the immediate problem.
