Self destructing pully belts why? #1287651
08/19/12 02:04 AM
08/19/12 02:04 AM
South San Francisco, Californi...
MidPenMopar Offline OP
Looking for fun? Keep looking
I was doing a car show today and when I opened the hood I saw the pulley for the alternator had self destructed and torn it's self to shreds. Luckily it lasted till I got home, but the belt is only about 500 miles old. It basically came apart and unraveled. The power steering belt is still perfect and I replaced then at the same time.
I was wondering if maybe over tightening it could cause this sort of premature wear??
The alternator is one of the aftermarket PowerMaster units Summit sells. It has been on the car for about 8 years and this is the first time i have had an issue like this. I use only the good Gates brand belts too.
Any ideas??
Re: Self destructing pully belts why? *DELETED* [Re: MidPenMopar] #1287652
08/19/12 02:45 AM
08/19/12 02:45 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Post deleted by Hugh Jorgan
Re: Self destructing pully belts why? [Re: Hugh Jorgan] #1287653
08/19/12 02:48 AM
08/19/12 02:48 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Wood or steel pulley?
Have you checked the cable?
Re: Self destructing pully belts why? [Re: Alaskan_TA] #1287654
08/19/12 02:54 AM
08/19/12 02:54 AM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Re: Self destructing pully belts why? [Re: MidPenMopar] #1287655
08/19/12 03:57 AM
08/19/12 03:57 AM
My Garage / Museum
idrivevintage Offline
Chrysler Plant
Chrysler Plant
My Garage / Museum
Look again, the long bolt that holds the alternator to the head could have backed out a bit and made contact with the belt...chewing it up
Thats happened to me before
Good luck...
Re: Self destructing pully belts why? [Re: MidPenMopar] #1287656
08/19/12 10:55 AM
08/19/12 10:55 AM
Any ideas??
If your alignment is good I'd say overtightening and sometimes a belt is just defective & doesn't last long but that is very rare
Re: Self destructing pully belts why? [Re: RapidRobert] #1287657
08/19/12 12:25 PM
08/19/12 12:25 PM
Any ideas??
Maybe that was it but i was always told to tighten the belt to the point that you could just turn the belt about 1/4 way around.
Re: Self destructing pully belts why? [Re: MidPenMopar] #1287658
08/19/12 12:43 PM
08/19/12 12:43 PM
I've heard that too but (just me) I go a bit looser
Re: Self destructing pully belts why? [Re: RapidRobert] #1287659
08/19/12 12:56 PM
08/19/12 12:56 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I've heard that too
That's a pretty subjective way to measure tension.... Is this a average guy twist, a Goldberg twist or some 12 YO kid twist? Are you going for a 1/4 twist with all your strength or a comfortable grab & twist...... Point is it could easily be to tight but with hands on experience you get a feel for what it needs... The proper way to set it is with a belt deflection gauge, good luck finding one.... Typically I go for about 1" of deflection in the middle of the belt when pressing with my thumb, but again, how hard do you press...
As has been mentioned pulley alignment, pulley condition, other things contacting the belt or just a defective belt... I don't think Gates has taken production to China butttttttttt...
Re: Self destructing pully belts why? [Re: 1_WILD_RT] #1287660
08/19/12 01:20 PM
08/19/12 01:20 PM
That came into play too maybe??
Re: Self destructing pully belts why? [Re: MidPenMopar] #1287661
08/19/12 02:04 PM
08/19/12 02:04 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Post a pic.
Re: Self destructing pully belts why? [Re: NITROUSN] #1287662
08/19/12 02:05 PM
08/19/12 02:05 PM
Post a pic.
Good idea, be right back!
Re: Self destructing pully belts why? [Re: NITROUSN] #1287663
08/19/12 02:55 PM
08/19/12 02:55 PM
The pully started to defray so badly the loose fibers grabbed the horn relay wires and yanked them into the alternator.
Re: Self destructing pully belts why? [Re: NITROUSN] #1287664
08/19/12 02:55 PM
08/19/12 02:55 PM
Re: Self destructing pully belts why? [Re: NITROUSN] #1287665
08/19/12 02:56 PM
08/19/12 02:56 PM
Re: Self destructing pully belts why? [Re: MidPenMopar] #1287666
08/19/12 04:14 PM
08/19/12 04:14 PM
Andrewh Offline
Andrewh  Offline
is that just the lighting, or is there an odd cup to the belt in the center?
like it dips in the middle?
Re: Self destructing pully belts why? [Re: Andrewh] #1287667
08/19/12 04:45 PM
08/19/12 04:45 PM
It did have an cup to it yes. Well none of the local parts stores sell GATES brand belts in that size so i will order one tomorrow. I am doing a major cleaning now in the engine bay anyway.
Re: Self destructing pully belts why? [Re: MidPenMopar] #1287668
08/19/12 05:13 PM
08/19/12 05:13 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you have a laser pointer, set it up so that it is centered on one of the pulleys, then rotate it to the other pulleys and see if it's centered on them as well. Looks like you might have a bit of a misalignment. Also inspect each pulley to make sure there are no burrs that might be shredding your belt.
Don't be the exception.
Re: Self destructing pully belts why? [Re: Supercuda] #1287669
08/19/12 06:53 PM
08/19/12 06:53 PM
Park Forest, IL
slantzilla Offline
Happy Birthday slantzilla  Offline
Park Forest, IL
Did they give you the right pitch belt for the pulleys? The fact that it's so deep in the pulleys and cupped leads me to believe it's the wrong belt.
Re: Self destructing pully belts why? [Re: slantzilla] #1287670
08/19/12 07:17 PM
08/19/12 07:17 PM
I have always used the stock belt for the 383 and this is the first time it has ever happened.
