Custom Window Net.. where from? #1284553
08/13/12 02:17 PM
08/13/12 02:17 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
This one pizzes me off a little as my non-rated custom sized window net is in perfect condition.. but to be "legal"
Where do you recommend getting a custom made SFI rated window made??
I have a trapezoid which measures
14.75 left side
15.75 top
22.25 right side
21.5 bottom
Re: Custom Window Net.. where from? [Re: Jeepmon] #1284554
08/13/12 03:28 PM
08/13/12 03:28 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Stroud does those for $80
2011 Drag Pak Challenger
Re: Custom Window Net.. where from? [Re: rickseeman] #1284555
08/13/12 03:31 PM
08/13/12 03:31 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
X2 for Stroud. I ordered on a MON. am and it was at my door on Fri.
Re: Custom Window Net.. where from? [Re: Jeepmon] #1284556
08/13/12 04:05 PM
08/13/12 04:05 PM
MN
73outlaw Offline
73outlaw  Offline
MN
summit now offers custom rjs nets for 42.99, online you have to call them and give measurements and then rjs calls you when they get the order and confirms the measurements and mount position.
It does show about a month out but it came in under 2 weeks for me!
quality net measurements right on.
and I should clarify it is a 27.1 cert
Re: Custom Window Net.. where from? [Re: 73outlaw] #1284557
08/13/12 09:08 PM
08/13/12 09:08 PM
K&Q va.
BIGBLOCK_KAT Offline
K&Q va.
X3 for stroud. My chassis builder had mine made
Re: Custom Window Net.. where from? [Re: BIGBLOCK_KAT] #1284558
08/14/12 01:21 AM
08/14/12 01:21 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Stroud or DJ Safety...Have both done this year.
Re: Custom Window Net.. where from? [Re: Al_Alguire] #1284559
08/14/12 02:34 AM
08/14/12 02:34 AM
Arizona
Chris'sBarracuda Offline
Arizona
Ribbon nets don't need to be re-certified..
Not sure what you have..
Chris..
Re: Custom Window Net.. where from? [Re: Chris'sBarracuda] #1284560
08/14/12 12:23 PM
08/14/12 12:23 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
Thanks for everyones suggestions..
I need some clarification here.. I read some information where it didnt matter if the net was ribbon or not... that the new NHRA rules said it needed to be SFI rated!!!
Is that correct or not? (btw, I do have a ribbon net)
Re: Custom Window Net.. where from? [Re: Jeepmon] #1284561
08/14/12 12:48 PM
08/14/12 12:48 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
mine HAVE been checked at all the divisional races this year. Was told after April they needed to be done and that was in Phoenix. In the beginning of the year the rulebook stated they needed to be SFI certified and I had both done as we raced in Febuary, so I got them done. In Phoenix I asked Lonnie and he said they pushed it back to April. Have not asked since then but it has been checked at all the races I have attended since. Both of mine are ribbon
Re: Custom Window Net.. where from? [Re: Jeepmon] #1284562
08/14/12 12:52 PM
08/14/12 12:52 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The ribbon style does NOT need to be re-certed..
I took a template into RJS(local to me) and they
made it up and I picked it up the next day... I'm
going with a different shape and will go back there
Re: Custom Window Net.. where from? [Re: Al_Alguire] #1284563
08/14/12 12:54 PM
08/14/12 12:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt know of this change.... good to know
EDIT
How many years on a ribbon before it needs re-cert....
more money again out of the pocket
Re: Custom Window Net.. where from? [Re: MR_P_BODY] #1284564
08/14/12 01:25 PM
08/14/12 01:25 PM
Sunnyvale, CA
Jeepmon Offline OP
Jeepmon  Offline OP
Sunnyvale, CA
EDIT
Thats what I made reference to in my first post.. I have a ribbon net and its in almost brand new condition... but based on the information I have, NHRA has now determined my net is unsafe because it doesnt have the cloth sticker on it..
Anyways.. its good to know and I'll be making a call to Strouds (or Summit)...
Re: Custom Window Net.. where from? [Re: MR_P_BODY] #1284565
08/14/12 01:26 PM
08/14/12 01:26 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
RJS made mine for my Challenger. I made a card board template & sent it to them. Fit perfectly when I got it back. Its was only $45.00 too.
Re: Custom Window Net.. where from? [Re: 6PKRTSE] #1284566
08/14/12 02:48 PM
08/14/12 02:48 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Talking window nets, NHRA does not specify how much forward the net should go. IHRA does by stating the net should come within 2 inches of the rearmost portion of the steering wheel.
Window Net Rules [Re: Blucuda413] #1284567
08/14/12 03:06 PM
08/14/12 03:06 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Guys, you need to go back and read the most recent rule changes. Changes that took effect on May 29 changed the ribbon rule back to not being required for recert. Most ET, Stock, SST, SG, and probably others.
Re: Window Net Rules [Re: Blucuda413] #1284568
08/17/12 03:47 AM
08/17/12 03:47 AM
Arizona
Arizona
That's what I said..
Chris..
Re: Window Net Rules [Re: Chris'sBarracuda] #1284569
08/17/12 04:06 AM
08/17/12 04:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Wouldn't it be nice if they could have all that finalized BEFORE we start racing
Re: Window Net Rules [Re: Chris'sBarracuda] #1284570
08/17/12 10:04 AM
08/17/12 10:04 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Chris..
So the current rule is the same as it was a few years
ago... where it is NOT required to be re-certed on
the ribbon style net
Re: Window Net Rules [Re: Al_Alguire] #1284571
08/17/12 10:09 AM
08/17/12 10:09 AM
Arizona
Arizona
Yep..
Hey, I bought a new one at the start of this year too, remember..
Chris..
Re: Window Net Rules [Re: Chris'sBarracuda] #1284572
08/17/12 12:36 PM
08/17/12 12:36 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
This is out of the NHRA rule book changes in May
An SFI 27.1 ribbon-type or mesh-type window net is mandatory on any full-bodied car running 7.49 (*4.49) or quicker. For full-bodied cars running 7.50 (*4.50) to 9.99 (*6.39) or if vehicle runs 135 mph or faster a ribbon-type or SFI 27.1 mesh-type window net is mandatory unless otherwise specified by class requirements. SFI 27.1 window net, when required, must be updated at two-year intervals from the date of manufacture.
