Need clutch suggestion #1284398
08/13/12 12:54 AM
08/13/12 12:54 AM
Garland, Texas
1badmopar Offline OP
Garland, Texas
I took my car to the track for the first time with the new TKO600. The clutch is fine on the street, but at the track it slips so bad I might as well be in neutral. Freewheeled to the rev limiter in both 1st and 2nd, then I just backed out of it.
It is a Keisler suggested SPEC stage 3 10.5". I argued with the tech on the phone, concerned if the clutch would be stout enough and he swore up and down that it would hold. I shoudl have know better!
Any suggestions for a 10.5" street/ strip clutch that will hold 710ft lbs in 3600 lb car?
I'm going to pull the trans this week and order the replacement.
1966 Plymouth Belvedere
520" RB w/ Indy 440-1 Heads
FiTech Fuel Injection
TKO 600 conversion
[img]https://flic.kr/p/2j1ejsK[/img]
Re: Need clutch suggestion [Re: 1badmopar] #1284399
08/13/12 02:28 AM
08/13/12 02:28 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I always had good luck with CFDF clutches. Never in anything with the power of your car, but a heavy 4x4 truck with a 440. I know someone on here has the information you need.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Need clutch suggestion [Re: 1badmopar] #1284400
08/13/12 10:54 AM
08/13/12 10:54 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Sounds like you have plenty of tire grip at the track. With that much weight and torque I think you're going to have to consider a dual disc setup. I know McLeod makes one, but I don't have any personal experience with them.
Re: Need clutch suggestion [Re: 5spdcuda] #1284401
08/13/12 11:42 AM
08/13/12 11:42 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
A stock rag disc /pressure plate will hold up with the weight and 10.5 slick if you have the proper gear for racing. What gears are you running? stock gears will smoke any disc.
Re: Need clutch suggestion [Re: rowin4] #1284402
08/14/12 02:22 AM
08/14/12 02:22 AM
Garland, Texas
Garland, Texas
Thanks for the input. I am running 3.91 gears, 28x12.5 ET Streets, and Caltracks with monoleafs. Car hooks good, just cannot hold the clutch.
Just hoping some of the other stick shift guys on the forum have a clutch that they really like. The SPEC was only rated at 600 ft lbs, and I'm sure that was in a lighter car.
TKO 600 conversion
Re: Need clutch suggestion [Re: 1badmopar] #1284403
08/14/12 10:35 AM
08/14/12 10:35 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I am in the process of installing a Mcleod RXT twin disc on my Challenger with a TKO600. There are a couple people on here that gave it good reviews.
Mcleod makes 2 versions a RST and RXT. RST has organic discs and the RXT has ceramic discs similar to their 600 series disc.
http://www.mcleodracing.com/products/RXT+Twin+Disc.mcl
Re: Need clutch suggestion [Re: RTSE4ME] #1284404
08/14/12 11:42 AM
08/14/12 11:42 AM
Holly, MI
JackGTX440 Offline
JackGTX440  Offline
Holly, MI
I too would say the McLeod dual disk. It should hold no problem.
Jack Irons Jr. '67 GTX, turbo 6.1 HEMI
Re: Need clutch suggestion [Re: JackGTX440] #1284405
08/14/12 12:12 PM
08/14/12 12:12 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I have an old Street Twin set-up in my Dart. It hooks good. Almost too good. There is no slip what so ever. I've come off the line already spinning when they had just prepped the starting line. I run 31x18.5x15's.
Re: Need clutch suggestion [Re: 70HemiGTX] #1284406
08/14/12 08:46 PM
08/14/12 08:46 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I vote dual disc too. I got a RST McLeod in my duster and love it. Drives like a stocker and holds great.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: Need clutch suggestion [Re: 71yelladustr] #1284407
08/15/12 01:34 AM
08/15/12 01:34 AM
Garland, Texas
Garland, Texas
Thanks everyone! I really appreciate the advice!
TKO 600 conversion
Re: Need clutch suggestion [Re: 1badmopar] #1284408
08/15/12 01:51 AM
08/15/12 01:51 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
call spec and talk to them, i had a 3+ in my dart for a short time. had a issue with it slipping. sent it back to them and they fixed it up. hit so hard when i got it back the trans broke. then i decided i needed a slipper clutch.. still have it, sure i'll use it in a serious street car one day.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Need clutch suggestion [Re: 68 HEMI GTS] #1284409
08/15/12 12:49 PM
08/15/12 12:49 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
This is what I'm afraid of......
Re: Need clutch suggestion [Re: 70HemiGTX] #1284410
08/15/12 03:22 PM
08/15/12 03:22 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
I ran a RST 23 spline dual setup on the street and track behind 525+hp and it was perfect. I just took it out and it looks like I just bought it. Never slipped at all.
I'm probably going to sell that unit soon....because....
I just upgraded to an 18 spline setup and obviously needed a new clutch. I got a clutch with my purchase and I like it on the street so far, but haven't been to the track yet.
The RST should be good for the 800hp like they claim. Great clutch!
