Need clutch suggestion
#1284398
08/13/12 12:54 AM
08/13/12 12:54 AM
Posts: 265 Garland, Texas
1badmopar
Garland, Texas
I took my car to the track for the first time with the new TKO600. The clutch is fine on the street, but at the track it slips so bad I might as well be in neutral. Freewheeled to the rev limiter in both 1st and 2nd, then I just backed out of it. It is a Keisler suggested SPEC stage 3 10.5". I argued with the tech on the phone, concerned if the clutch would be stout enough and he swore up and down that it would hold. I shoudl have know better! Any suggestions for a 10.5" street/ strip clutch that will hold 710ft lbs in 3600 lb car? I'm going to pull the trans this week and order the replacement.
1966 Plymouth Belvedere 520" RB w/ Indy 440-1 Heads FiTech Fuel Injection TKO 600 conversion [img] https://flic.kr/p/2j1ejsK[/img]
Re: Need clutch suggestion
[Re: 1badmopar]
#1284399
08/13/12 02:28 AM
08/13/12 02:28 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
I always had good luck with CFDF clutches. Never in anything with the power of your car, but a heavy 4x4 truck with a 440. I know someone on here has the information you need.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: rowin4]
#1284402
08/14/12 02:22 AM
08/14/12 02:22 AM
1badmopar
Garland, Texas
Thanks for the input. I am running 3.91 gears, 28x12.5 ET Streets, and Caltracks with monoleafs. Car hooks good, just cannot hold the clutch.
Just hoping some of the other stick shift guys on the forum have a clutch that they really like. The SPEC was only rated at 600 ft lbs, and I'm sure that was in a lighter car.
[Re: 1badmopar]
#1284403
08/14/12 10:35 AM
08/14/12 10:35 AM
Posts: 2,046 MD
RTSE4ME
MD
I am in the process of installing a Mcleod RXT twin disc on my Challenger with a TKO600. There are a couple people on here that gave it good reviews. Mcleod makes 2 versions a RST and RXT. RST has organic discs and the RXT has ceramic discs similar to their 600 series disc. http://www.mcleodracing.com/products/RXT+Twin+Disc.mcl
[Re: RTSE4ME]
#1284404
08/14/12 11:42 AM
08/14/12 11:42 AM
Posts: 453 Holly, MI
JackGTX440
Holly, MI
I too would say the McLeod dual disk. It should hold no problem.
Jack Irons Jr.
'67 GTX, turbo 6.1 HEMI
[Re: 1badmopar]
#1284408
08/15/12 01:51 AM
08/15/12 01:51 AM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
call spec and talk to them, i had a 3+ in my dart for a short time. had a issue with it slipping. sent it back to them and they fixed it up. hit so hard when i got it back the trans broke. then i decided i needed a slipper clutch.. still have it, sure i'll use it in a serious street car one day.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#1284409
08/15/12 12:49 PM
08/15/12 12:49 PM
Posts: 2,364 PA
70HemiGTX
PA
This is what I'm afraid of......
