Re: What Cylinder heads for a 499 low deck
[Re: tboomer]
#1284318
08/18/12 10:37 AM
08/18/12 10:37 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
If you want to have it repaired,I know someone who is very good at it but a little slow!Due to a lot of race engine work.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: jafr]
#1284320
08/19/12 12:13 PM
08/19/12 12:13 PM
Posts: 3,082 St. Paul , Mn.
tubtar
St. Paul , Mn.
This one is a little clearer.
The first one was plenty clear...that you very much. Mein Gott in Himmel , that had to sound as bad as it looks. ![](/ubbthreads/images/graemlins/no.gif) The link to the craigslist post is an awful nice price.........I wish I did big blocks.
[Re: tboomer]
#1284322
08/19/12 03:45 PM
08/19/12 03:45 PM
Posts: 13,202 aZLiViN
J_BODY
aZLiViN
Wow!! That is hurt!! I saw an Edelbrock Victor that was in worse shape than that one that was repaired. Radar at R&J Performance farmed it out to someone but I can't remember who it was...
Probably the same guy who tried to fix our W5 head up in Iowa. Couldn't fix it due to the crappy aluminum. Larry Demers recommended him and was shocked he couldn't fix it. He had nothing but great things to say about him and they had sent some pretty messed up heads to him and they came back looking like new.
[Re: J_BODY]
#1284323
08/19/12 07:17 PM
08/19/12 07:17 PM
MRMOPAR622
Sweet Home Alabama
The aluminum head or block repair is not cheap,and on a head unless you have a lot of $$$ in port work it may be cheaper just to replace it than fix it.It always ends up costing more than the estimate they give you.And to be fair to the repair shops some times you find more damage than you 1st thought when you start the work. If I were you I would step up to the 440-1 heads,that way you would have room to go later. PS It would not be a bad idea to if you go the 440-1 route to save your heads and look for a good deal on a used head to replace the damaged head.That way you end up with 2 sets of heads.
