Re: What Cylinder heads for a 499 low deck
[Re: jafr]
#1284294
08/12/12 10:52 PM
08/12/12 10:52 PM
Thumperdart
State of confusion
Are you getting rid of them because of the dropped seat or wanting more power?
[Re: jafr]
#1284295
08/13/12 12:27 AM
08/13/12 12:27 AM
Posts: 43,233 Bend,OR USA
Cab_Burge
Last night my Indy SR heads droped a valve seat which broke the valve and piston. I am now in the market for a new set of heads among other parts. My SRs worked very well after Nick at Comp U Flow ported them but I think it is time to move on and try a new head. I am looking at Indy 440-1s B-1 BS or Edelbrock Victors.These heads will be on a 499 low deck motor in a tube chassis 69 Dart. With the SR heads I was running low 5.70s in the 1/8th mile. All suggestions and opinions appreciated. Thanks, Joe
I've built and dyno tested motors with SR with M.W. ports, they flowed 340 CFM at .700 lift on a Super Flow 600 bench at 28 inches, I had a set of B1-BS CNC ported by Modern Cylinder heads to M.W. ports, they flowed 350 at .700,.800 and .900 on the same bench by the same tech, I had Modern cylinder heads CNC a set of 440-1 and had them change the intake valves to 2.250, they flowed 370 CFM at .600,.700 and all the way up to 1.0 on the same bench,(several years apart)by the same tech My message is the 440-1 CNC ported will flow a lot more air than the same size SR ported heads will with the smaller valves Call around and see if any of the shops have a set of 440-1 ported, ready to assemble or done and ready to ship
[Re: jafr]
#1284298
08/13/12 08:40 AM
08/13/12 08:40 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
With 499 cubes you can make roughly 850 hp with fully ported 440-1 heads. That is about the upper limit on a good budget. There is more available hp wise but the cost goes up fast when you start looking into the parts needed. The rpm will go up some as well. For that power you will most likely need to shift at 7300 or there abouts. You could keep the revs down if you really want to stay at 7,000 or below but it will cost some of the power. The 440-1 heads will make great power from about 5000 up. I ran 9.30s at 2000 DA with 2980 weight, 499, unported 440-1 heads and alky as an example of what they can do if you shift at 6800. For valvetrain take a good look at T & D stuff in as high a rocker ratio as they will make (1.7?). I have had a lot of greaf with Jesel stuff. You can move up to a B1 head at this point if you have the budget for pistons and other items required, and those heads should allow for another 50 to 75 hp over the 440-1, maybe more. If you chose to go B1, I strongly suggest getting a good center weighted crank to keep the block alive. I am going to post results of my switch to a center weighted crank after I post this.
[Re: jafr]
#1284299
08/13/12 12:10 PM
08/13/12 12:10 PM
Posts: 31,050 Oregon
AndyF
MW ports on a 500 inch short block will give you a torque peak in the 5000 to 5500 rpm. Peak power is usually around 7000 rpm.
I don't think you'll see much difference between the SR heads and the -1 heads if they are both ported the same.
If you need new rocker arms I'd suggest getting the -1 heads machined for Jesel rocker arms right out of the box. The Jesel setup cost more up front, but it sure is nice to work with over time.
Dwayne is always a good guy to talk to on builds like this. He can set you up with the heads that you need and give you some cam suggestions at the same time.
[Re: jafr]
#1284301
08/13/12 12:54 PM
08/13/12 12:54 PM
Posts: 16,928 NC
440Jim
NC
If you were happy with the performance of the SR combo, and only one head is damaged, then you could buy one head and have it ported to match the other one. That is less than buying two new heads!
But, I agree now is the time to step up if you want more power. IMO, the larger port of the 440-1 will make more power than the SR. And now is the time to get a good CNC port job. I like the 2.25" intake valve option, just make sure the piston valve reliefs are large enough in diameter for them.
The Edelbrock Victor with good CNC porting can match the 440-1. And I like their stuff. But I think it will cost you a little more in both work (pushrod fit, etc) and money since you already have the Indy valley plate, external oiling kit, etc.
I just don't think the B1-BS is up to the task. The B1 originals or MC are a big step up, but will cost even more.
[Re: jafr]
#1284303
08/13/12 02:27 PM
08/13/12 02:27 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
It doesn't make any difference what cylinder head you choose, the difference is in who prepares it. Pick any head you want 440-1, B1 BS or Victor. Even the EZ head will go 370 cfm. Just get the right guy to port them.
Darn, you can get 730 HP with factory iron heads at 6600-6700 rpm.
[Re: LaRoy Engines]
#1284304
08/13/12 06:06 PM
08/13/12 06:06 PM
gregsdart
The grief I had with Jesel rocker arms is due to the offset on the intake valves in a 440-1 type head combined with a poor design for holding the intake rockers in place. Even with offset lifters the angle is enough to hammer the rocker arm over against the piece that it registers against. That piece is a little C clip on the rocker shaft that positions the rocker. It rides against the needle bearing cage in the rocker arm. The needle bearing cage wears on the C clip and actually thins them out over time and at some point they will break. The needle bearing cages get beaten up from the repeated impact every valve cycle and the edges crack, deform and then the needles inside the bearings seize and gall the shafts. If you don't catch it soon enough the bearings will come apart and the little needle bearing rollers will fall into the motor and find their way to the oil pump, seize it up and shear off the tip of your bronze gear distributor/pump drive shaft. And then you are waiting on the right size engine bearings to put your motor back together! I hope my -.001 rod bearings get hear tomorrow! Oh, forgot about the oil pump and expensive oil pump cover that also got destroyed. The end result of all this is over $1200 in repairs to just the rockers alone, and finally engineering a system for holding the rockers in place that doesn't rely on either the bearing cages or a C clip. So choose wisely, and hope you get many runs out of what ever you build
[Re: dragram440]
#1284307
08/14/12 10:38 AM
08/14/12 10:38 AM
Posts: 2,648 GA
Boosted
GA
I like the 572-13's... That is what is on the Indy 528 we have..
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
[Re: jafr]
#1284309
08/14/12 02:41 PM
08/14/12 02:41 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I think it depends alot on what rpm do you want your peak power at. I think the -1s will want more rpm and the B1s even more.
Mopar to the bone!!!
[Re: jafr]
#1284312
08/15/12 08:02 AM
08/15/12 08:02 AM
Posts: 4,072 Mo.
racerx
Mo.
What's the weight on your car?assuming under 3000 lbs
