Re: What Cylinder heads for a 499 low deck [Re: racerx] #1284313
08/15/12 09:01 AM
08/15/12 09:01 AM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
I am running a stock 400 block with a Hughes main girdle, I would like to keep the shift point around 6800 and cross the finish line at 7000 or less. Probably 95% of my racing is 1/8th mile. Yes the car is under 3000lb, it is in the 2800lb range with me.
I will get some pics posted this evening.
Thanks guys for all your help, Joe
Re: What Cylinder heads for a 499 low deck [Re: jafr] #1284314
08/15/12 10:40 AM
08/15/12 10:40 AM
Washington, IL
Hughes Offline
Hughes  Offline
Washington, IL
If you decide you want a set of fully CNC ported Edelbrock Victor heads we have them on sale. $200.00 off regular price and free shipping. We have flow charts on our web page. (http://www.hughesengines.com/TechArticles/1headflowchartscomparisons.php#4658S3). This would make a set of heads right at $2600.00. Give me a call if you are interested. We'll throw in a free t-shirt for you as well.
Kevin (309-745-9558)
Re: What Cylinder heads for a 499 low deck [Re: Hughes] #1284315
08/18/12 10:22 AM
08/18/12 10:22 AM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
Here is a picture of the damaged head. Sorry it took so long I have been out of town with no net. access.
Re: What Cylinder heads for a 499 low deck [Re: jafr] #1284316
08/18/12 10:24 AM
08/18/12 10:24 AM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
This one is a little clearer.
Re: What Cylinder heads for a 499 low deck [Re: jafr] #1284317
08/18/12 10:27 AM
08/18/12 10:27 AM
tboomer Offline
tboomer  Offline
Wow!! That is hurt!! I saw an Edelbrock Victor that was in worse shape than that one that was repaired. Radar at R&J Performance farmed it out to someone but I can't remember who it was...
Re: What Cylinder heads for a 499 low deck [Re: tboomer] #1284318
08/18/12 10:37 AM
08/18/12 10:37 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
If you want to have it repaired,I know someone who is very good at it but a little slow!Due to a lot of race engine work.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: What Cylinder heads for a 499 low deck [Re: MRMOPAR622] #1284319
08/18/12 01:44 PM
08/18/12 01:44 PM
SoCal
Brian Hafliger Offline
SoCal
Use Kevin Self in OK!
Brian Hafliger
Re: What Cylinder heads for a 499 low deck [Re: jafr] #1284320
08/19/12 12:13 PM
08/19/12 12:13 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
The first one was plenty clear...that you very much.
Mein Gott in Himmel , that had to sound as bad as it looks.
The link to the craigslist post is an awful nice price.........I wish I did big blocks.
Re: What Cylinder heads for a 499 low deck [Re: tubtar] #1284321
08/19/12 01:37 PM
08/19/12 01:37 PM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
It didn't sound that bad. It all busted loose coming out of the burnout, the starter didn't hear it I shut the car off and told them to send the other car down the track. I thought it had broke a rocker.Believe it or not the short block can be saved, a sleeve in the block and 1 piston.
I think the B1-BS head would probably be fine with the 499 but I don't know if it would give me a lot of room to grow. If I had a unlimited budget I would buy 2 sets of heads, the B1-BS heads for my 470 short block and a set of 440-1s or possibly a set of ported Victors for the 499. Unfortunaetly I don't have that option, I am going to be stuck with the heads I buy for awhile. Decisions decisions.
Re: What Cylinder heads for a 499 low deck [Re: tboomer] #1284322
08/19/12 03:45 PM
08/19/12 03:45 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Probably the same guy who tried to fix our W5 head up in Iowa. Couldn't fix it due to the crappy aluminum. Larry Demers recommended him and was shocked he couldn't fix it. He had nothing but great things to say about him and they had sent some pretty messed up heads to him and they came back looking like new.
Re: What Cylinder heads for a 499 low deck [Re: J_BODY] #1284323
08/19/12 07:17 PM
08/19/12 07:17 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
The aluminum head or block repair is not cheap,and on a head unless you have a lot of $$$ in port work it may be cheaper just to replace it than fix it.It always ends up costing more than the estimate they give you.And to be fair to the repair shops some times you find more damage than you 1st thought when you start the work.
If I were you I would step up to the 440-1 heads,that way you would have room to go later.
PS It would not be a bad idea to if you go the 440-1 route to save your heads and look for a good deal on a used head to replace the damaged head.That way you end up with 2 sets of heads.
Re: What Cylinder heads for a 499 low deck [Re: MRMOPAR622] #1284324
08/20/12 11:31 AM
08/20/12 11:31 AM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
I'm putting a set of MP stage 6 MW heads ported by Brian @ IMM in CA that flow around 350 CFM on a 474 (400 low deck) and then I have a set of Stage 6 Chapmen CNC 385 MW thats going on a 512 low deck. The best thing about stage 6 on a low deck you can use any RB intake.
Brian
