470 stroker valvetrain issues #1284107
08/12/12 05:38 PM
08/12/12 05:38 PM
San Diego, CA, United States
Texas_Charger Offline OP
Hello everyone, this is going to be long so please bear with me...
I recently built a 470 stroker using 440source aluminum heads and a hughes hyd. flat-tappet camshaft. Initially I had the 440source rocker arms and shafts on it, but because uneasy about the quality of those rockers so I decided to switch to the Crane Gold roller tip rockers.
I'm glad I did too because the "super heavy duty" shafts they sold me had been eaten alive by the roller bearings in their rockers. there were grooves worn into the shafts from the bearings that you could hang a fingernail on.
So I decided to use the stock shafts that I pulled off my 383 magnum when I switched to the new Crane gold rockers because the stock shafts were in really good shape. I checked to make sure I had the shafts installed right-side-up so they are oiling properly.
As per the Hughes instructions, I initially set preload at .08 on all the rockers.
When I start the engine from being cold it runs awesome, idles great, and the valvetrain is very quiet. However, when it reaches operating temperature (approx. 160-200 degrees) the valvetrain starts clattering terribly and sounds like an engine with no oil pressure. I have plenty of oil pressure.(40psi hot at idle) the idles also gradually accelerates from 600rpm cold to 1000 rpm hot once the valvetrain starts sounding like a diesel.
I tried adjusting the preload down to .04 because I'd heard that too much preload could cause noise when it got hot but it didnt help at all. Any suggestions as to what could be the problem?
the specs are:
470 shortblock, 10.0:1 compression.
440 source ported heads
Hughes camshaft 242/246 duration, .555/.569 lift
1.6:1 crane gold roller rockers.
Comp lifters
comp 3/8" pushrods
Any help would be greatly appreciated... I'm pulling my hair out and I'm afraid I might be doing damage to the cam if the valvetrain is that noisy...
Thanks!
1971 Dodge Charger SE 470/727/3.91 Suregrip
2016 Dodge Challenger Hellcat, 6-speed
1980 Pontiac Trans Am, Y84, WS6
2002 Ram 2500 Cummins/6-speed/2WD/QC
1971 Ford F-350 Ranger
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284108
08/12/12 06:06 PM
08/12/12 06:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
How many threads of the adjuster are showing under the rocker arm ? you only want 2 or 3 so that the tips of your pushrods are oiled properly.
Look at the tips of the pushrods to see if they are burning up ???
Re: 470 stroker valvetrain issues [Re: JohnRR] #1284109
08/12/12 06:33 PM
08/12/12 06:33 PM
When I pulled it apart today there were three threads showing underneath the rocker. Thanks!
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284110
08/12/12 06:43 PM
08/12/12 06:43 PM
Did this start when you swapped out the rockers/shafts?
Re: 470 stroker valvetrain issues [Re: RapidRobert] #1284111
08/12/12 06:51 PM
08/12/12 06:51 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
This is the 1st I've heard of a hyd flat tappet wanting lash. Usually they are tightened 1.5 turns past 0 lash, to get the adjustment in the middle of what the lifter can adjust for.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 470 stroker valvetrain issues [Re: RapidRobert] #1284112
08/12/12 06:53 PM
08/12/12 06:53 PM
Yes, it was very quiet before and it all started after i swapped the new rockers and shafts in.
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284113
08/12/12 07:52 PM
08/12/12 07:52 PM
and the stock shafts/Crane gold rockers were quiet on the 383 magnum I'm assuming. You're seeing no interference anywhere and no binding on the rockers (needle bearings or side clearance) that could be causing a problem with the lifters and you do have preload for the hydraulics
Re: 470 stroker valvetrain issues [Re: RapidRobert] #1284114
08/12/12 07:58 PM
08/12/12 07:58 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
are the shafts upside down?
Re: 470 stroker valvetrain issues [Re: lewtot184] #1284115
08/12/12 08:11 PM
08/12/12 08:11 PM
On the 383 magnum the stock shafts had stock rockers and were very quiet. I made sure the shafts were right-side-up when I installed them so they should be good there.
If the shafts weren't oiling properly they should make noise all the time and not just when the engine is hot. Is that a reasonable notion?
Thanks!
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284116
08/12/12 08:14 PM
08/12/12 08:14 PM
This is the first time the new Crane gold rockers have been used
Re: 470 stroker valvetrain issues [Re: RapidRobert] #1284117
08/12/12 08:39 PM
08/12/12 08:39 PM
Yes, the crane gold rockers were new in the box when I got them.
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284118
08/12/12 08:57 PM
08/12/12 08:57 PM
I'm thinking the Cranes' are the problem just not sure how. I would recheck their slip fit on the shafts cold and when hot/noisy shut it down & undo the adjusters/take out the pushrods & see if any of them are binding(reciprocating and side to side). You'd need to work fast to get em while they are hot which may take several efforts as it may only be one or several that are binding so all would need to be checked while hot. I'm doing alot of guessing here. This is a tough one. Plus there's the (related) idle speedup issue
Re: 470 stroker valvetrain issues [Re: RapidRobert] #1284119
08/13/12 06:57 AM
08/13/12 06:57 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
If you have roller bearing rocker arms, you are going to need hardened shafts. I would get the Crane shafts if you have Crane rocker arms.
This is the land of the free because of the brave
Re: 470 stroker valvetrain issues [Re: HemiRick] #1284120
08/13/12 09:13 AM
08/13/12 09:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
He never said lash , he said PRELOAD , .080 is too much , even .040 is a little excessive .
Crane Golds are not roller bearing rockers , the body rides on the shaft .
OP , have you pulled the shafts and rockers to see if there is anything going on?
Also when you say you checked the shafts I assume was no wear where the old rockers rode on the shaft ?
How did you go about setting preload , ?
Re: 470 stroker valvetrain issues [Re: JohnRR] #1284121
08/13/12 09:58 AM
08/13/12 09:58 AM
I pulled the shafts and rockers yesterday to see if there was anything weird happening and it looked OK to me. The 383 magnum was a low-mile engine and the shafts were still in really good shape.
I thought .08 was an excessive amount of preload as well but thats what the Hughes cam instructions said to use.
I set preload by rotating the engine, setting intake when exhaust was opening and exhaust when intake was closing. I turned the pushrods with my finger and slowly tightened the adjusters until i felt resistance, then tightened 2.5 turns for .08 the first time and 1.25 turns for .04 the second.
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284122
08/13/12 11:02 AM
08/13/12 11:02 AM
Idaho
LaRoy Engines Offline
Idaho
Make sure the pushrods are not rubbing on the intake port wall. The Stealth heads have a problem with that.
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284123
08/13/12 11:06 AM
08/13/12 11:06 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
I don't see anything wrong with your procedures except that .080 which I also think is excessive, is just a little under two full turns of the adjuster. A 3/8 in. fine thread has 24 threads to the inch. One full turn equals .0416. Two full turns would be .0833. I wish I could be more helpful, but I think you'll just have to take them off and examine everything until you find out what's going on.
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284124
08/13/12 11:15 AM
08/13/12 11:15 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
When I setup preload with a hydralic cam, I do it with the intake removed. Not all rockers get the same amount of turns, there all different depending how much preload they need. Again, there never all the same!
Watch the plunger in the lifter and give it enough preload but not too much. Got to watch the plunger and who cares how many turns I have at the rocker arms, just as long as it within reason so the oiling is good.
Your'll never get it right now without pulling the intake and setting it up by sight. And who cares how many turns you have!! You have to see the lifter to determine wether the plunger is up or down in the lifter when you set it up.
I have been running Crane gold rockers on both my cars for 20+ years now.340 and 440
Re: 470 stroker valvetrain issues [Re: Challenger 1] #1284125
08/13/12 12:14 PM
08/13/12 12:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Some people care and it does matter, if his pushrods are too long or too short it could cause issues .
Re: 470 stroker valvetrain issues [Re: Texas_Charger] #1284126
08/13/12 12:57 PM
08/13/12 12:57 PM
Try using 1/4 to 1/2 a turn of preload from zero HOT I know that is(resetting the rocker preload hot) a real pain so you can try 1/8 to 3/8 turn cold on iron heads OOP, Stealth aluminum heads on this motor
