Nothing fell off #1283652
08/11/12 06:33 PM
08/11/12 06:33 PM
nielsville, minn.
Q
quickd100 Offline OP
Q
nielsville, minn.
Well I just got home from the drag strip. The truck motor had it's first drag strip outting. I only ran it to the 1/8 mile mark as it developes a rather severe vibration in the chassis around 95-100mph. I have some chassis tuning to do and need to have the convertor tightened up quite a bit. It's stalling at the hp peak,(5900) rather than the torque peak, (4800).
All in all it was a successful first outting, it ran a 6.53 in the 1/8. The truck picked the front wheels up 6-8" on launch but then wanted to go to the left out of the groove and would spin a bit until I was able to wrestle it back into the goove. I believe there is a few tenths left I can knock off once I get everything straightened out. Dave
Re: Nothing fell off [Re: quickd100] #1283653
08/11/12 06:45 PM
08/11/12 06:45 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
That is impressive . Man I miss my old 60.
Re: Nothing fell off [Re: justinp61] #1283654
08/11/12 08:53 PM
08/11/12 08:53 PM
Roseville MN
72swgnr Offline
72swgnr  Offline
Roseville MN
Check your photobucket.
Re: Nothing fell off [Re: 72swgnr] #1283655
08/11/12 09:45 PM
08/11/12 09:45 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Re: Nothing fell off [Re: slantzilla] #1283656
08/11/12 10:05 PM
08/11/12 10:05 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice going Dave. Thats some power as no offense meant but thats like pushing a shoebox down the track and that takes much hp. Ron
Re: Nothing fell off [Re: quickd100] #1283657
08/11/12 10:17 PM
08/11/12 10:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Not bad.... whats that thing weigh.... you got out..
had some fun beating on it and made it home in 1 piece...
what do you have for rear suspension... trying to
figure out why its going left on the launch... either
a brake hanging or it has too much preload but if
I remember its a leaf spring.. are you running Caltracs
Re: Nothing fell off [Re: MR_P_BODY] #1283658
08/11/12 11:06 PM
08/11/12 11:06 PM
nielsville, minn.
Q
Q
nielsville, minn.
Ron; It's more like a barn door, 38.5 square feet of area. Mike; I built a 4-link from scratch a couple years ago. I'm sure it just needs some adjusting. The vibration I think is pinion angle under load.
All in all it ran fairly well for an untested (at the strip) chassis setup. 3860lbs. Dave
Re: Nothing fell off [Re: quickd100] #1283659
08/11/12 11:18 PM
08/11/12 11:18 PM
MR_P_BODY Offline
MR_P_BODY  Offline
4-link... sounds like you need to move the pinion angle
(4-links like 1* or less but not zero) and reduce
some of the preload on the RR... my buddy has a 52
ford PU with a bore 460... he runs 11.50 with 1.4x
60' times.... he's a couple pounds heavier than you
and I mean just a couple... good job... get the 4-link
squared away and you'll pick up(no punnn....lol)
Re: Nothing fell off [Re: MR_P_BODY] #1283660
08/12/12 09:38 PM
08/12/12 09:38 PM
nielsville, minn.
Q
Q
nielsville, minn.
Checked the pinion angle today and found it was 3 degrees positive, I adjusted it to 1-1/2 degrees negative. Drove the truck and it ran much better. I've got to sit down and watch Billy Shope's 'Just Suspensions' again and then adjust the 4-link. Dave
Re: Nothing fell off [Re: quickd100] #1283661
08/12/12 09:59 PM
08/12/12 09:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
WAY cool...........gotta love fast trucks.
Re: Nothing fell off [Re: Thumperdart] #1283662
08/12/12 10:41 PM
08/12/12 10:41 PM
nielsville, minn.
Q
Q
nielsville, minn.
I'm hoping it picks up a bit more before I'm done. My goal is to have to slow it down. Dave
Re: Nothing fell off [Re: quickd100] #1283663
08/12/12 10:50 PM
08/12/12 10:50 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`d say you`re well on your way........
Re: Nothing fell off [Re: quickd100] #1283664
08/13/12 12:16 PM
08/13/12 12:16 PM
Dave, are you saying negative pinion angle is down or up in relation to the driveshaft intersection at the pinion shaft?
Re: Nothing fell off [Re: Cab_Burge] #1283665
08/13/12 10:39 PM
08/13/12 10:39 PM
nielsville, minn.
Q
Q
nielsville, minn.
Cab; Down for negative, up for positive.
I've got to round up a couple of scales to set this 4-link. Dave
Re: Nothing fell off [Re: quickd100] #1283666
08/13/12 11:26 PM
08/13/12 11:26 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Dave, I hope you have a good aftermarket and well balanced driveshaft under there. That kind of power and those kinds of speeds demand a quality d-shaft.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Nothing fell off [Re: DusterDave] #1283667
08/14/12 07:20 AM
08/14/12 07:20 AM
nielsville, minn.
Q
Q
nielsville, minn.
Dave; I had a custom shaft made up for it when the 528 went in. After adjusting the pinion angle the vibration has gone away.Dave
Re: Nothing fell off [Re: quickd100] #1283668
08/14/12 09:46 AM
08/14/12 09:46 AM
tboomer Offline
tboomer  Offline
Dave...That old truck would be a blast at street night at our track...The ultimate sleeper/rice killer!!
Re: Nothing fell off [Re: tboomer] #1283669
08/14/12 07:04 PM
08/14/12 07:04 PM
nielsville, minn.
Q
Q
nielsville, minn.
Ted; I still get laughed at unless they hear it running or see it make a pass. Dave
Re: Nothing fell off [Re: quickd100] #1283670
08/15/12 02:20 PM
08/15/12 02:20 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Dave, no one was laughing at the last cruise night you were at. In fact when you fired it up one guy had goose bumps on his arms.
Re: Nothing fell off [Re: Hemi_Ram] #1283671
08/15/12 08:06 PM
08/15/12 08:06 PM
nielsville, minn.
Q
Q
nielsville, minn.
Larry; I does sound better than it looks. Dave
