Re: Nothing fell off
[Re: slantzilla]
#1283656
08/11/12 10:05 PM
08/11/12 10:05 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Nice going Dave. Thats some power as no offense meant but thats like pushing a shoebox down the track and that takes much hp. Ron
[Re: quickd100]
#1283657
08/11/12 10:17 PM
08/11/12 10:17 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Not bad.... whats that thing weigh.... you got out.. had some fun beating on it and made it home in 1 piece... what do you have for rear suspension... trying to figure out why its going left on the launch... either a brake hanging or it has too much preload but if I remember its a leaf spring.. are you running Caltracs
[Re: quickd100]
#1283659
08/11/12 11:18 PM
08/11/12 11:18 PM
MR_P_BODY
Ron; It's more like a barn door, 38.5 square feet of area. Mike; I built a 4-link from scratch a couple years ago. I'm sure it just needs some adjusting. The vibration I think is pinion angle under load. All in all it ran fairly well for an untested (at the strip) chassis setup. 3860lbs. Dave
4-link... sounds like you need to move the pinion angle (4-links like 1* or less but not zero) and reduce some of the preload on the RR... my buddy has a 52 ford PU with a bore 460... he runs 11.50 with 1.4x 60' times.... he's a couple pounds heavier than you and I mean just a couple... good job... get the 4-link squared away and you'll pick up(no punnn....lol)
[Re: Thumperdart]
#1283662
08/12/12 10:41 PM
08/12/12 10:41 PM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
WAY cool...........gotta love fast trucks.
I'm hoping it picks up a bit more before I'm done. My goal is to have to slow it down. Dave
[Re: quickd100]
#1283664
08/13/12 12:16 PM
08/13/12 12:16 PM
Posts: 43,218 Bend,OR USA
Cab_Burge
Dave, are you saying negative pinion angle is down or up in relation to the driveshaft intersection at the pinion shaft?
[Re: quickd100]
#1283666
08/13/12 11:26 PM
08/13/12 11:26 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Dave, I hope you have a good aftermarket and well balanced driveshaft under there. That kind of power and those kinds of speeds demand a quality d-shaft.
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: tboomer]
#1283669
08/14/12 07:04 PM
08/14/12 07:04 PM
quickd100
nielsville, minn.
Dave...That old truck would be a blast at street night at our track...The ultimate sleeper/rice killer!!
Ted; I still get laughed at unless they hear it running or see it make a pass. Dave
