Re: suntach, msd6al tach adapter
[Re: skelator]
#1283594
08/11/12 05:55 PM
08/11/12 05:55 PM
Posts: 52,972 Romeo MI
MR_P_BODY
i think i got everything figured out as to what goes to where. whats the easiest way i can tap into the ignition wiring?
Coil lead at the box.. if thats what your talking about... or are you talking at the key ![](/ubbthreads/images/graemlins/wave.gif)
[Re: skelator]
#1283596
08/11/12 07:16 PM
08/11/12 07:16 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
MSD 8920?
I ran the red to an ignition hot terminal on a Painless Wiring fuseblock, black to ground, white to MSD tach output, violet to a terminal strip so I could hook everything needing an RPM signal to that.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: skelator]
#1283598
08/11/12 10:10 PM
08/11/12 10:10 PM
MR_P_BODY
i got it all setup only thing i noticed was it really dosent register at idle. maybe cuse its a sun tach? i think it was like 3 bucks. its the 3 3/8 super tach 2. i put in a 3k chip and it was cutting out around 2800. so i assume the tach is a bit off and not the msd.
I would think both are off... those chips arent all that accurate ... dont know why it isnt seeing idle RPM... do you have the booster on it (I think thats what they use to use with the Sun tach and MSD.....
I want to find a 3" to 3.5" tach for my Rampage... I've got the 5" tach but thats too big ![](/ubbthreads/images/graemlins/wave.gif)
