suntach, msd6al tach adapter #1283591
08/11/12 04:25 PM
08/11/12 04:25 PM
skelator Offline OP
skelator  Offline OP
ok i got a suntach and a msd tach adapter. can someone tell me how to hook up the wires on the adapter? the adapter has a violet,red,white,black.
the tach has green which is the signal wire according to the instructions, black which is ground, red is hot and white is lamp.
i got all new harnesses and i have yet to cut into them and would love to avoid this or use as few splices as possible. thanks
Re: suntach, msd6al tach adapter [Re: skelator] #1283592
08/11/12 04:28 PM
08/11/12 04:28 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Maybe try the msd site for instructions?
Re: suntach, msd6al tach adapter [Re: RobX4406] #1283593
08/11/12 05:14 PM
08/11/12 05:14 PM
skelator Offline OP
skelator  Offline OP
i think i got everything figured out as to what goes to where. whats the easiest way i can tap into the ignition wiring?
Re: suntach, msd6al tach adapter [Re: skelator] #1283594
08/11/12 05:55 PM
08/11/12 05:55 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Coil lead at the box.. if thats what your talking about...
or are you talking at the key
Re: suntach, msd6al tach adapter [Re: MR_P_BODY] #1283595
08/11/12 06:28 PM
08/11/12 06:28 PM
skelator Offline OP
skelator  Offline OP
only info i can find just says ign. so im not really sure. any thoughts?
Re: suntach, msd6al tach adapter [Re: skelator] #1283596
08/11/12 07:16 PM
08/11/12 07:16 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
MSD 8920?
I ran the red to an ignition hot terminal on a Painless Wiring fuseblock, black to ground, white to MSD tach output, violet to a terminal strip so I could hook everything needing an RPM signal to that.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: suntach, msd6al tach adapter [Re: Adobedude] #1283597
08/11/12 09:46 PM
08/11/12 09:46 PM
skelator Offline OP
skelator  Offline OP
i got it all setup only thing i noticed was it really dosent register at idle. maybe cuse its a sun tach? i think it was like 3 bucks. its the 3 3/8 super tach 2. i put in a 3k chip and it was cutting out around 2800. so i assume the tach is a bit off and not the msd.
Re: suntach, msd6al tach adapter [Re: skelator] #1283598
08/11/12 10:10 PM
08/11/12 10:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think both are off... those chips arent all
that accurate ... dont know why it isnt seeing idle RPM...
do you have the booster on it (I think thats what
they use to use with the Sun tach and MSD.....
I want to find a 3" to 3.5" tach for my Rampage...
I've got the 5" tach but thats too big
Re: suntach, msd6al tach adapter [Re: MR_P_BODY] #1283599
08/11/12 11:33 PM
08/11/12 11:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Back in the stone age ( early 80's ) I had a Sun tach read at approximately 1/2 actual engine speed with an MSD.
They sold a tach adapter that put it right , but I can't remember what the P/N was.
