Brakes - Help! #1283576
08/11/12 03:26 PM
08/11/12 03:26 PM
Wisconsin
70hemi4spdbee Offline OP
Wisconsin
Front disc brakes won't fully release. 70 Roadrunner originaly a drum drum car. Now front disc, drum rear. Front disc brakes will not fully release. I can turn the tire but they are definitely dragging. New Hemi MC (The Ram Man) and booster. All lines are new to include an Inline brand brake block with disc brake provision. Changed calipers and have same result. Front rubber lines are new as well...everything is new with the exception of pedals. Rear brakes do not drag......only the fronts. Excessive brake dust on front brakes as well which tells me they have been dragging for a while.
Re: Brakes - Help! [Re: 70hemi4spdbee] #1283577
08/11/12 03:31 PM
08/11/12 03:31 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Unbolt the master cylinder from the booster. See if that releases the brakes. Push rod coming out of the booster maybe to long.
Re: Brakes - Help! [Re: 70hemi4spdbee] #1283578
08/11/12 03:33 PM
08/11/12 03:33 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Early design brake calipers always drag slightly, thats why allot of drag racers use drum brakes.. By the term "I can turn it by hand" do you mean with one hand or do you need to grab it with two hands & muscle it some? If you give it a good spin will it spin more than one turn or stop as soon as you stop applying force?
Modern design calipers have seals designed to slightly retract the piston which helps fuel mileage, early ones don't....
Re: Brakes - Help! [Re: 1_WILD_RT] #1283579
08/11/12 04:01 PM
08/11/12 04:01 PM
Wisconsin
Wisconsin
OK...unbolted the master cylinder from the brake booster. Still dragging. I checked under the dash and I see no rod as with drum brake cars. Probably becuase if have the Hemi booster. After setting for a few minutes I can turn the tire by hand but just, if I stop turning it stops immediately. When I drive the car and come to a stop light the car will not roll. You can feel the front discs are dragging. That coupled with a tremendous amount of brake dust tells me something is wrong. I checked the steel wheels to see if they were hot but were not any warmer than the rear wheels. Perplexing.... I do not want to go on a long haul and have a fire....bad juju.
Re: Brakes - Help! [Re: 70hemi4spdbee] #1283580
08/11/12 04:34 PM
08/11/12 04:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
OK you eliminated the first conclusion that perhaps the pushrod from the booster, which is ajustable, was not over adjusted/misadjusted causing a possible residual pressure problem in the front calipers, by unbolting the master from the booster...
next is that junk IN-LINE manufactured proportioning valve, they have had a bad run of repros, has been discussed many times here by those that had issues with them, replace it with a FINE-LINES manfactured proportioning valve, you may see the same PN@ on fine-lines website as the IN-LINE PN#...both companies at one time had the same vendor, hence the same number, FINE-LINES has pulled all their old stock and replaced it with another vendor to eliminate customer hassles like what your experiencing, IN-LINE however continues to sell their junk PV's
Wayne (RAMMAN) puts out a great product, but if he's supplying IN-LINE PV's as part of his systems, he doing himself a disservice supplying them...
Mike
Re: Brakes - Help! [Re: DAYCLONA] #1283581
08/11/12 04:41 PM
08/11/12 04:41 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Re: Brakes - Help! [Re: 1_WILD_RT] #1283582
08/11/12 06:52 PM
08/11/12 06:52 PM
crack a caliper bleeder valve to release the pressure & jack it up & bearhug the wheels again which'll tell you if it's a psi problem (as said prop valve) or the calipers/adapters themselves. I had one that seemed to hard to turn (A body BBP discs) & I replaced the caliper with a cheap reman & it turned alot easier, not free by any means which wont happen but easier enough that I was comfortable with it. There is not supposed to be a RPV in the disc half of a M/C but wouldn't hurt to check by sticking a drill bit deep into the brass cone in the disc half & you'll feel the springy RPV if the assembly line people made a mistake & installed one
Re: Brakes - Help! [Re: RapidRobert] #1283583
08/12/12 07:48 AM
08/12/12 07:48 AM
Wisconsin
Wisconsin
Just to be sure I checked my work. Unbolted the master cylinder from the booster and the brakes released somewhat. Before I start removing the brake block I want to eliminate a too long pushrod. I looked under the dash and see no pushrod? This car has the Hemi brake booster with the levers. Where is the adjustment? Not under the dash obviously.....in the engine bay behind the booster perhaps?
The RAM MAN did not provide the brake block, only the booster which seems to be a very good unit. I purchased the brake block seperately from Inline Tube about three years ago.
When I purchased the brake block it was a complete unit with the prop valve attached to the same mounting arm. Not sure if this is the correct unit. Seems I have seen other B bodies with the rear prop valve, or maybe it is a rear bias valve, bolted to the frame under the car downstream from the block? Do I have an incorrect brake block for a 70 B body? Is the prop valve and the bias valve two seperate issues here?
Re: Brakes - Help! [Re: 70hemi4spdbee] #1283584
08/12/12 09:00 AM
08/12/12 09:00 AM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..sounds like there could be a residual pressure valve in the master.
just a thought.
Re: Brakes - Help! [Re: can.al] #1283585
08/12/12 09:19 AM
08/12/12 09:19 AM
IN
ahy Offline
ahy  Offline
IN
just a thought.
Agree... as suggested above next diagnostic is to crack a bleeder and see if that releases some of the drag. If so there is a residual pressure valve in the master or in the distribution block or one of the above is malfunctioning.
Also, there is a possibility the flex hoses are collapsed inside... they will expand to apply brakes but close up afterwards and retain pressure. I had this on a DD Neon and changed hoses based on a tip from MOPARTs. It cleared right up. The hoses were old.
Re: Brakes - Help! [Re: 70hemi4spdbee] #1283586
08/12/12 10:28 AM
08/12/12 10:28 AM
Unbolted the master cylinder from the booster and the brakes released somewhat. where is the adjustment?
I think we found the problem. Unbolt the M/C from the booster & pull it forward a bit & you'll see the threaded rod with the round nub on the end. Measure the depth of the recess in the M/C piston and measure how far out the rod protrudes from the booster & adj the rod so there is ~1/16" clearance between the rounded nub and the bottom of the piston recess.
Re: Brakes - Help! [Re: RapidRobert] #1283587
08/12/12 07:30 PM
08/12/12 07:30 PM
Wisconsin
Wisconsin
Rapid Robert,
You were right, drove the car and the brakes dragged. Brought it right in an unbolted the MC and pulled it away from the booster. The brakes released. The rod appears to be sticking out of the booster at least an inch and a half. How do you adjust the rod? Does it just screw in?
At this point I have found the problem thanks to you folks...now to fix it.
Re: Brakes - Help! [Re: 70hemi4spdbee] #1283588
08/12/12 07:56 PM
08/12/12 07:56 PM
Todd nailed her 1st. Yes it's right hand threads & should have a little locknut on the threads
