Re: Brakes - Help!
[Re: 70hemi4spdbee]
#1283578
08/11/12 03:33 PM
08/11/12 03:33 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Early design brake calipers always drag slightly, thats why allot of drag racers use drum brakes.. By the term "I can turn it by hand" do you mean with one hand or do you need to grab it with two hands & muscle it some? If you give it a good spin will it spin more than one turn or stop as soon as you stop applying force?
Modern design calipers have seals designed to slightly retract the piston which helps fuel mileage, early ones don't....
Re: Brakes - Help!
[Re: 70hemi4spdbee]
#1283580
08/11/12 04:34 PM
08/11/12 04:34 PM
Posts: 18,157 Mass
DAYCLONA
Mass
All lines are new to include an Inline brand brake block with disc brake provision.
OK you eliminated the first conclusion that perhaps the pushrod from the booster, which is ajustable, was not over adjusted/misadjusted causing a possible residual pressure problem in the front calipers, by unbolting the master from the booster...
next is that junk IN-LINE manufactured proportioning valve, they have had a bad run of repros, has been discussed many times here by those that had issues with them, replace it with a FINE-LINES manfactured proportioning valve, you may see the same PN@ on fine-lines website as the IN-LINE PN#...both companies at one time had the same vendor, hence the same number, FINE-LINES has pulled all their old stock and replaced it with another vendor to eliminate customer hassles like what your experiencing, IN-LINE however continues to sell their junk PV's
Wayne (RAMMAN) puts out a great product, but if he's supplying IN-LINE PV's as part of his systems, he doing himself a disservice supplying them...
Mike
Re: Brakes - Help!
[Re: 1_WILD_RT]
#1283582
08/11/12 06:52 PM
08/11/12 06:52 PM
RapidRobert
crack a caliper bleeder valve to release the pressure & jack it up & bearhug the wheels again which'll tell you if it's a psi problem (as said prop valve) or the calipers/adapters themselves. I had one that seemed to hard to turn (A body BBP discs) & I replaced the caliper with a cheap reman & it turned alot easier, not free by any means which wont happen but easier enough that I was comfortable with it. There is not supposed to be a RPV in the disc half of a M/C but wouldn't hurt to check by sticking a drill bit deep into the brass cone in the disc half & you'll feel the springy RPV if the assembly line people made a mistake & installed one
Re: Brakes - Help!
[Re: can.al]
#1283585
08/12/12 09:19 AM
08/12/12 09:19 AM
Posts: 7,664 IN
ahy
IN
..sounds like there could be a residual pressure valve in the master. just a thought.
Agree... as suggested above next diagnostic is to crack a bleeder and see if that releases some of the drag. If so there is a residual pressure valve in the master or in the distribution block or one of the above is malfunctioning.
Also, there is a possibility the flex hoses are collapsed inside... they will expand to apply brakes but close up afterwards and retain pressure. I had this on a DD Neon and changed hoses based on a tip from MOPARTs. It cleared right up. The hoses were old.
Re: Brakes - Help!
[Re: 70hemi4spdbee]
#1283588
08/12/12 07:56 PM
08/12/12 07:56 PM
RapidRobert
Todd nailed her 1st. Yes it's right hand threads & should have a little locknut on the threads
