New hemi lifters #1281567
08/08/12 03:32 PM
08/08/12 03:32 PM
Seattle WA
RichV Offline OP
RichV  Offline OP
Seattle WA
I have heard that the new hemi hydraulic roller lifters go to higher RPMs than the LA magnum style. What would it take to use these lifters in a LA magnum block? Can you just bush the lifter bores and feed them oil through the rockers? Do you need full time oil feed to the rockers? Can you get more lift out of them than the LA magnums which uncover their oil band at a moderate amount of lift?
Re: New hemi lifters [Re: RichV] #1281568
08/08/12 05:39 PM
08/08/12 05:39 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
I doubt it would be an easy swap. Among other things, the Gen3 hemi feeds the lifters through the push rods. Most engines are he other way around. I'm sure it could be done....but there are prob. easier/cheaper ways to get what your after.
DAve
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: New hemi lifters [Re: Dave_S] #1281569
08/09/12 09:58 AM
08/09/12 09:58 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Gen III Hemi oils through the push rods, yes, but from the lifters up I believe. You would have to completely reconfigure the oiling system on a LA engine to do this I believe
Alan Jones
