Edelbrock STR-15 linkage and set up help? #1280724
08/07/12 02:22 AM
08/07/12 02:22 AM
Davis, California, USA
MrBelvedere2 Offline OP
Well I finally found an Edelbrock STR-15 cross ram intake at the swap meet today for an actual reasonable price. It has some of the linkage mounts and rods to mount to the carb, but it doesn't look like it is all there. Here is a picture, Does anyone have any pics of a setup with the rest of the linkage and the kickdown hooked up? Does anyone know where to purchase new linkages for these setups? what do I need to make it complete? thanks for any info and help.
1965 Plymouth Belvedere II hardtop
Re: Edelbrock STR-15 linkage and set up help? [Re: MrBelvedere2] #1280725
08/07/12 03:31 AM
08/07/12 03:31 AM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
You need another pivot rod and linkage rod like the passenger side. The cable linkage from the car goes directly to drivers side carb. I would change the linkage to carbs to heim ends it will not bind that way. There are some mods for that intake that really help the performance. Basic mods are in the Direct-Connection racing book. Good Luck!!! poppaj
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: Edelbrock STR-15 linkage and set up help? [Re: poppaj] #1280726
08/07/12 07:01 PM
08/07/12 07:01 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
Touch base with member LAR414: he set up his Dart with one within the past 2 years IIRC.
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: Edelbrock STR-15 linkage and set up help? [Re: EWJ] #1280727
08/08/12 07:56 AM
08/08/12 07:56 AM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
I run the STR12 and it uses the same parts by looking at what you have there,I will get you a good pic today and post it later.
Re: Edelbrock STR-15 linkage and set up help? [Re: moparclown] #1280728
08/08/12 10:19 AM
08/08/12 10:19 AM
Thank you I'd apreciate it
Re: Edelbrock STR-15 linkage and set up help? [Re: MrBelvedere2] #1280729
08/08/12 11:02 PM
08/08/12 11:02 PM
canaan ct usa
moparclown Offline
moparclown  Offline
canaan ct usa
I just ran out in the garage and snapped this pic.
I couldn't find a great deal of info on the str intakes.
Re: Edelbrock STR-15 linkage and set up help? [Re: moparclown] #1280730
08/09/12 08:47 PM
08/09/12 08:47 PM
Thanks for takig the pics it helps me out figuring out the linkage setup. How did you set up the kickdown but I don't see it at all so i assume yours is a 4 speed car? And where did you get the clamp on arms and rods mine has some but missing one more?
