Hand e-brake lever
#1280125
08/05/12 10:08 PM
08/05/12 10:08 PM
Posts: 3,712 Sacramento, Ca
Darius
Sacramento, Ca
I am going to have to install a hand style e-brake lever in my GTX. I have enough room between the driver seat and the door sill to install something....appx4" on the flat of the floor and another 3"or so to the door panel. About 7" total from the edge of the seat to the door. Any ideas as to a particular brand or model?
Driving modern convenience in classic beauty
Re: Hand e-brake lever
[Re: Darius]
#1280126
08/05/12 10:37 PM
08/05/12 10:37 PM
Posts: 1,168 Vancouver, WA
MoparMarq
Vancouver, WA
IIRC, the e-brake handle on my sister's '04 Jeep GC is mounted on the right side of the trans hump as part of the console. Might work OK where you're thinking of locating it. The handle is nice looking, so that's a plus. Don't know about the specific mount arrangement though. The one in wife's '92 Acura Vigor (only built between '92 and '94, but later RS's and RL's wre similar) is mounted on a flat on the tunnel hump, so that's a possibility, too. Leather (looking) handle and leather boot. Usually black. Great excuse to go meandering through the JY, IMO. Just curious - how you going to route the cable to the passenger side?
[Re: OzHemi]
#1280129
08/06/12 08:54 AM
08/06/12 08:54 AM
Darius
Sacramento, Ca
That would be awesome OZ, thanks.
[Re: Darius]
#1280130
08/06/12 01:37 PM
08/06/12 01:37 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
I have a Lokar setup like West shows. I am a little concerned about drive shaft clearance, hopefully it will clear with a 1350 slip yoke and 3" shaft.
383, Hemi 4-Speed, AlterKtion, D60
[Re: Crazy68Dart]
#1280131
08/06/12 02:13 PM
08/06/12 02:13 PM
Posts: 4,233 petaluma,ca. u.s.a.
west
petaluma,ca. u.s.a.
It should clear fine. You will have to remove the drive shaft to make adjustments though. Id like to have one that has the cable come up into the interior.
[Re: west]
#1280132
08/06/12 05:06 PM
08/06/12 05:06 PM
MoparMarq
Vancouver, WA
FWIW, the lever, ratchet, mount, balance bar, and cables are all on the interior on the Vigor, then the two individual cables pass through the floor to the calipers. Hasn't required any adjusting, but the console is easy to remove - shifter knob, and four screws.
[Re: Darius]
#1280133
08/06/12 06:25 PM
08/06/12 06:25 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Here it is...pretty simple. The cable just has a small clevis end that connects to the handle (and is anchored to the floor from memory)
[Re: GreenGlow]
#1280137
08/07/12 09:24 AM
08/07/12 09:24 AM
Darius
Sacramento, Ca
Thanks for the pics OZ. That looks like it could work . I will keep it in mind in my "search" .
