went to mid michigan yesterday #1278126
08/02/12 09:59 AM
08/02/12 09:59 AM
Mt Morris Michigan
mopar dave Online content OP
mopar dave  Online Content OP
Mt Morris Michigan
best the 408 could do was a 10.65@127.6 in 83* weather. 60 was 1.53. just could'nt get the car to 60 any better with shock adjustments.
first pass was 10.66@126.9-1.52 60. went down 2 on the jetting and went 10.69@126.5-1.54 60. went up 1 and went 10.73@126.6-1.59 60 spun. timing went from 32* to 36* and went 10.65@127.6-1.53 60. went up two more on jetting and ran 10.66@127.6. jet changes made little differences and timing got 1 more mph. car went straight so i did'nt touch the cal-trac adjustment. 60'ed better on ss springs with a 1.49 best.
Re: went to mid michigan yesterday [Re: mopar dave] #1278127
08/02/12 10:15 AM
08/02/12 10:15 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
For caltracs you need atleast 4 in. of front travel looks like you have about two. Lower front and realign to give it more travel.
JAKES AUTOMOTIVE
Re: went to mid michigan yesterday [Re: JAKE68] #1278128
08/02/12 12:21 PM
08/02/12 12:21 PM
Mt Morris Michigan
Mt Morris Michigan
i measured 6" on front end travel. tubular control arms with hyme joints and calvert 90/10's. stiffening rear shocks a click at a time had no real effect.
Re: went to mid michigan yesterday [Re: mopar dave] #1278129
08/02/12 12:44 PM
08/02/12 12:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You might need to soften the rear shocks for more
extension to plant the tires harder... bad tracks..
softer... good tracks ... stiffer
Re: went to mid michigan yesterday [Re: MR_P_BODY] #1278130
08/02/12 02:57 PM
08/02/12 02:57 PM
Mt Morris Michigan
Mt Morris Michigan
mid michigan had the track preped good for the $50,000 super pro challenge which starts today. i started on 4 and 5 and went to 8 and 9 one click at a time without much difference. best 60 was on 4 and 5(4 drivers and 5 pass.).
i'm now thinking the 50/50 mix of 93 shell and vp110 killed it. i'm not convinced it needed any race fuel with 11.3:1 and .036 quench. no evidence on plugs. the smaller tire (27") probably did'nt help much either.
Re: went to mid michigan yesterday [Re: mopar dave] #1278131
08/02/12 05:58 PM
08/02/12 05:58 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
I dont know how you are mesuring your front end travel, and I am not saying that you are wrong but I looked at your vidio 10 times with soemone else also looking on and it sure looks like it only moves a couple of inches.
JAKES AUTOMOTIVE
Re: went to mid michigan yesterday [Re: JAKE68] #1278132
08/03/12 12:15 AM
08/03/12 12:15 AM
Mt Morris Michigan
Mt Morris Michigan
well maybe i'm not measuring correctly. at static ride height i measure between the bottom of oil pan and ground,then i jack front up til one tire or both leave the ground and take another measure between pan and ground. i take first measure and subtract from second measure and that figure is my total travel.
Re: went to mid michigan yesterday [Re: mopar dave] #1278133
08/03/12 12:35 AM
08/03/12 12:35 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Just measure from the fender lip right above the tire
centerline with you in the seat then jack it up and
soon as the tire will start to turn measure it again
at the same point
Re: went to mid michigan yesterday [Re: MR_P_BODY] #1278134
08/03/12 01:50 AM
08/03/12 01:50 AM
Mt Morris Michigan
Mt Morris Michigan
ok i will remeasure and see what i have.
Re: went to mid michigan yesterday [Re: mopar dave] #1278135
08/03/12 11:02 AM
08/03/12 11:02 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The reason you measure at the tire centerline is that
anything in front of it will have a ratio(if you
were to measure it at the front bumper it travel
farther before the tire comes off the ground)to
give you a larger number... thats why you need to
do it on the tire C/L(splindle C/L)
Re: went to mid michigan yesterday [Re: MR_P_BODY] #1278136
08/03/12 02:40 PM
08/03/12 02:40 PM
Mt Morris Michigan
Mt Morris Michigan
remeasured. 5" travel with me in it. dont know why it looks like it only has 2" at launch. i know this last time out didnt have enough power to pull the wheels. still think i over octaned it.
Re: went to mid michigan yesterday [Re: mopar dave] #1278137
08/03/12 05:31 PM
08/03/12 05:31 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
My car is 12.7.1 and i run 50-50 pump 97 and 112 race fuel, my old motor was same comp as yours and i used the pump 97 only with .039 quench.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: went to mid michigan yesterday [Re: deaks] #1278138
08/03/12 05:45 PM
08/03/12 05:45 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Mick
Still gonna matter what cam is in it.... check the
cranking pressure
Re: went to mid michigan yesterday [Re: mopar dave] #1278139
08/03/12 06:01 PM
08/03/12 06:01 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I`m really happy w/VP-100 unleaded gas.........you should try some cos mixing sucks and pump gas can vary too much in my opinion. How many passes on your tires and yes, I`d get at least get a 28" tire under there if you can.
Re: went to mid michigan yesterday [Re: Thumperdart] #1278140
08/04/12 01:00 AM
08/04/12 01:00 AM
Mt Morris Michigan
Mt Morris Michigan
cranking pressure was 185#/cyl avg. not sure what octane i need but vp110 and shell 93 was clearly too much. tires are brand new. i will have to do some body work to get a 28" tire on there without rubbing. never rubbed with the ss springs but a 28" tire does with the cal-tracs.
at this point i would be better off putting the ss springs and the 28" tires back on and sell the cal-tracs,i 60 ed better.
Re: went to mid michigan yesterday [Re: mopar dave] #1278141
08/04/12 01:06 AM
08/04/12 01:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
At 185 you can run premium by it self but you want
to make sure its good quality and not all over the
place on octane.... I know when I went from 112 to
110 I picked up with no other changes
Re: went to mid michigan yesterday [Re: MR_P_BODY] #1278142
08/04/12 01:08 AM
08/04/12 01:08 AM
Mt Morris Michigan
Mt Morris Michigan
thanks mike. i did have one cylinder that was 195 psi.
Re: went to mid michigan yesterday [Re: mopar dave] #1278143
08/04/12 02:05 AM
08/04/12 02:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
If that one was a END cyl I wouldnt worry much BUT I
would try to keep the engine cooler with a lower stat
Re: went to mid michigan yesterday [Re: MR_P_BODY] #1278144
08/04/12 10:00 AM
08/04/12 10:00 AM
Mt Morris Michigan
Mt Morris Michigan
number 5 and i run a 180 stat.
Re: went to mid michigan yesterday [Re: mopar dave] #1278145
08/04/12 10:11 AM
08/04/12 10:11 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My aluminum headed 340 was 11.2-1 with .039" quench and ran on pump 93. I tried 110 race gas in it one time and it slowed down.
