Type "F" Tranny Fluid ? #1278077
08/02/12 07:46 AM
08/02/12 07:46 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Does it hurt to put Type F tranny fluid in a Mopar instead of the Dexron?
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Type "F" Tranny Fluid ? [Re: TimS] #1278078
08/02/12 07:56 AM
08/02/12 07:56 AM
SC
Southern Wolf Offline
SC
My transmission man told me to use type F, he said it would make it shift better
Re: Type "F" Tranny Fluid ? [Re: TimS] #1278079
08/02/12 08:19 AM
08/02/12 08:19 AM
scratchnfotraction Offline
No. it will work fine in it and is recomended by most people for a firmer shift.
just picked up a case of type F for my BB 727 swap this weekend myself.
Re: Type "F" Tranny Fluid ? [Re: scratchnfotraction] #1278080
08/02/12 09:27 AM
08/02/12 09:27 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
I run Type F in my 727. When Pete Tritak rebuilt it for me that is what he told me to use. I didn't argue with him.
Scott
1969 Super Bee, 383/4 speed
Re: Type "F" Tranny Fluid ? [Re: TimS] #1278081
08/02/12 10:21 AM
08/02/12 10:21 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Yes Type F is the accepted grade for performance 727/904's something to do with the grit factor being higher for firmer shifts. Most if not all performance transmission builders will recommend Type F like one builder told me don't was your money on trick shift just use type F!
Re: Type "F" Tranny Fluid ? [Re: Dodgem] #1278082
08/02/12 06:37 PM
08/02/12 06:37 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
One of the regular village bragarts over on the slantsix board was bashing the use of Type F fluid in Mopar transmissions. He claims it degrades the bands and clutches because in the petroleum based form, it can't handle the heat as well as Dexron 2.
While there is some truth to the temperature rating of petrolium Type F as compared to petrolium Dexron, the thermal problem goes away when you switch to synthetic Type F.
In the synthetic form, the Type F can handle much higher thermal loads while still providing enhanced thermal stability and lubricity than petrolium transmision fluids, regadless of the type of fluid ie Dextron or Type F.
If you are going to use Type F, pay a bit more and run the synthetic Type F.
Re: Type "F" Tranny Fluid ? [Re: jbc426] #1278083
08/02/12 07:15 PM
08/02/12 07:15 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Synthetic is not necessary in Mopar transmissions. Regular type F works great to give firm shifts and doesn't break down under normal temps.
Re: Type "F" Tranny Fluid ? [Re: stumpy] #1278084
08/02/12 08:01 PM
08/02/12 08:01 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
to be quite honest ive used both in the same transmission and have noticed no difference in either in shifting quality.
Re: Type "F" Tranny Fluid ? [Re: mcmopars] #1278085
08/02/12 08:08 PM
08/02/12 08:08 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
and to be quite honest ive used whatever was available in cases with no ill effects.mixing one with another,i know your not suppossed too but,kinda like the power steering pump,ive used what i had to at times with no catastrophic failure. so no ,using type f is o.k.
Re: Type "F" Tranny Fluid ? [Re: TimS] #1278086
08/02/12 08:18 PM
08/02/12 08:18 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Well I just dumped some coin on my trans last year and the builder said to run Dextron in it...I'll go by that.
Coming soon!!!!
Re: Type "F" Tranny Fluid ? [Re: TimS] #1278087
08/02/12 08:34 PM
08/02/12 08:34 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Got a Torqueflite that's been living on Type F for 20 years...
It's been subjected to beaucoup heat-more than once...
As far as 'band and clutch degradation'???
Just had the pan down not too long ago...
Looked just like it did when I bolted it on...
Re: Type "F" Tranny Fluid ? [Re: RSNOMO] #1278088
08/02/12 08:41 PM
08/02/12 08:41 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I asked this question about a month ago and got the same feedback. I had the converter out of the car and decided to do a complete drain of the trans as well. I like the feel of the trans with the type F. It does shift firmer. the fluid was cheaper too. I can that a win-win.
Re: Type "F" Tranny Fluid ? [Re: Kern Dog] #1278089
08/02/12 10:29 PM
08/02/12 10:29 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I'll try it in my 69 Super Bee. Thanks very much for the input.
Re: Type "F" Tranny Fluid ? [Re: TimS] #1278090
08/02/12 11:23 PM
08/02/12 11:23 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We've used nothing but Type F since 1977..never any problems with it.
Nautilus Racing-
Re: Type "F" Tranny Fluid ? [Re: Chris2581] #1278091
08/19/12 01:37 PM
08/19/12 01:37 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
I was told 35 years ago, Type F only in mopars. That's all that I've ever put in them. I don't know as though Dextron would hurt anything, but Type F for me.
DRIVE EM, DONT HIDE EM.
Re: Type "F" Tranny Fluid ? [Re: ledft79] #1278092
08/19/12 02:40 PM
08/19/12 02:40 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
well i hope type F doesnt have more grit----hoping it is less slippery....bob
Re: Type "F" Tranny Fluid ? [Re: savoy64] #1278093
08/19/12 04:16 PM
08/19/12 04:16 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I have a good supply of ATF+4 since I worked at a Dodge dealer for 24 years. All my brother and I have ever used is the Mopar ATF+. It shifts great and looked like brand new when I dropped the pan. I dont think I will drain it and add type F to see if it is any faster. Ron
Re: Type "F" Tranny Fluid ? [Re: TimS] #1278094
08/19/12 04:31 PM
08/19/12 04:31 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Type F was developed by Ford (hence the F) to help their auto trans shift more crisp like the Chrysler and GM autos I was told. Type F has less "cushion agents" in it to achieve the firmer shifts. With less cushion agents it should shift firmer but not be a problem for other components that need lubrication. That's all they do with so called "racing automatic transmission fluid" is reduce the cushion agents to minimize the clutch engagement slip or cushion.
Re: Type "F" Tranny Fluid ? [Re: A12] #1278095
08/19/12 05:15 PM
08/19/12 05:15 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
It's not about "cushioning", it's all about the coefficient of friction (the ratio of the force of friction between two bodies). Type F has a more aggressive COF.
Re: Type "F" Tranny Fluid ? [Re: John_Kunkel] #1278096
08/19/12 06:07 PM
08/19/12 06:07 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
John you might want to do a search for cushioning agents and clutches to see what I meant. We had these issues for years in motorcycle wet clutches and there are agents that are meant to cushion or soften clutch engagement and at the worst cause clutch slippage. Won't argue the COF but what determines that is the fluid or oil and the type of friction modifiers that are added to them. Type F has less friction modifiers and or cushioning agents ADDED to it than Dextron or other transmission fluids and transmission oils so it has a higher COF
