Type "F" Tranny Fluid ?
#1278077
08/02/12 07:46 AM
08/02/12 07:46 AM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Does it hurt to put Type F tranny fluid in a Mopar instead of the Dexron?
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Type "F" Tranny Fluid ?
[Re: TimS]
#1278079
08/02/12 08:19 AM
08/02/12 08:19 AM
Posts: 15,487 Florida
scratchnfotraction
No. it will work fine in it and is recomended by most people for a firmer shift.
just picked up a case of type F for my BB 727 swap this weekend myself.
[Re: Dodgem]
#1278082
08/02/12 06:37 PM
08/02/12 06:37 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
One of the regular village bragarts over on the slantsix board was bashing the use of Type F fluid in Mopar transmissions. He claims it degrades the bands and clutches because in the petroleum based form, it can't handle the heat as well as Dexron 2.
While there is some truth to the temperature rating of petrolium Type F as compared to petrolium Dexron, the thermal problem goes away when you switch to synthetic Type F.
In the synthetic form, the Type F can handle much higher thermal loads while still providing enhanced thermal stability and lubricity than petrolium transmision fluids, regadless of the type of fluid ie Dextron or Type F.
If you are going to use Type F, pay a bit more and run the synthetic Type F.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Kern Dog]
#1278089
08/02/12 10:29 PM
08/02/12 10:29 PM
TimS
Walton, Indiana
I'll try it in my 69 Super Bee. Thanks very much for the input.
[Re: Chris2581]
#1278091
08/19/12 01:37 PM
08/19/12 01:37 PM
Posts: 587 minot north dakota
ledft79
minot north dakota
I was told 35 years ago, Type F only in mopars. That's all that I've ever put in them. I don't know as though Dextron would hurt anything, but Type F for me.
DRIVE EM, DONT HIDE EM.
[Re: savoy64]
#1278093
08/19/12 04:16 PM
08/19/12 04:16 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have a good supply of ATF+4 since I worked at a Dodge dealer for 24 years. All my brother and I have ever used is the Mopar ATF+. It shifts great and looked like brand new when I dropped the pan. I dont think I will drain it and add type F to see if it is any faster. Ron
[Re: A12]
#1278095
08/19/12 05:15 PM
08/19/12 05:15 PM
Posts: 25,821 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It's not about "cushioning", it's all about the coefficient of friction (the ratio of the force of friction between two bodies). Type F has a more aggressive COF.
[Re: John_Kunkel]
#1278096
08/19/12 06:07 PM
08/19/12 06:07 PM
Posts: 21,514 N.E. OHIO, USA
A12
N.E. OHIO, USA
John you might want to do a search for cushioning agents and clutches to see what I meant. We had these issues for years in motorcycle wet clutches and there are agents that are meant to cushion or soften clutch engagement and at the worst cause clutch slippage. Won't argue the COF but what determines that is the fluid or oil and the type of friction modifiers that are added to them. Type F has less friction modifiers and or cushioning agents ADDED to it than Dextron or other transmission fluids and transmission oils so it has a higher COF
