Gear Vendored 727 and a sure grip #1277423
08/01/12 02:42 AM
08/01/12 02:42 AM
east bay ca
torqueaddict Offline OP
east bay ca
Hey guys the trans guy I use to build my tranmissions was going to put a 4 pinion piece in place of the 3 to handle more torque for my stroker. I have decided to try and get a gear vendor unit and I am worndering will ths enhancment be necessary with the gear vendro unit or is the combo of the 727 and gear vendor bullet proof on theyre own. Also I am curious what all could be added to a sure grip pumpkin to make it more durable, also if I have a 323 unit is it possible to buy parts for 410 unit or is that alot of work for what your getting? Also how hard are 410 units to find? Thanks guy!
Anthony
Re: Gear Vendored 727 and a sure grip [Re: torqueaddict] #1277424
08/01/12 08:44 PM
08/01/12 08:44 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Re: Gear Vendored 727 and a sure grip [Re: Kern Dog] #1277425
08/01/12 09:25 PM
08/01/12 09:25 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I dont understand him either ..
I am truckless..
Re: Gear Vendored 727 and a sure grip [Re: 340SHORTY] #1277426
08/01/12 09:33 PM
08/01/12 09:33 PM
GA
roadrunninMark Offline
GA
Translation--- wants to know if he needs the 4th thing in the trans to handle more power for his stroker and a gear vendors or is the 3 standard thing is enough. 2nd ? was what he needs to make the 8 3/4 stronger to handle more power as well.
Re: Gear Vendored 727 and a sure grip [Re: roadrunninMark] #1277427
08/01/12 09:48 PM
08/01/12 09:48 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Oh,, a 4 planetary unit stronger than a 3 planetary unit. Id highly suggest a bolt in sprag. Use a clutch style suregrip unit..
I am truckless..
Re: Gear Vendored 727 and a sure grip [Re: 340SHORTY] #1277428
08/02/12 06:27 AM
08/02/12 06:27 AM
east bay ca
east bay ca
Sorry guys I did mean the 4 pinion planetary gears. I couldn't think when I made the post. Also how can I tell if it's a clutch style unit or a less desirable unit? Thanks
Re: Gear Vendored 727 and a sure grip [Re: torqueaddict] #1277429
08/02/12 12:54 PM
08/02/12 12:54 PM
dogdays Offline
dogdays  Offline
4 pinions are stronger than 3, 5 are stronger than 4!
The bolt-in sprag is a good idea, as is a billet drum (so I've heard).
The Gear Vendors unit doesn't decrease the load on the transmission, so transmission strengthening is still a good thing.
You need to find pictures of the two different Sure Grip units and look at what you have. If it's a 489 case, it should have the cone type, if a 742 case it should be the clutch type and if it's a 741 it could be either. And, of course, anything could have been swapped into any case over the last 40 years!
Can you swap your 3.23s for 4.11s? Sure, this is a job for a rear end specialist, but it's done all the time. The 3.91 gearset seems to be the most popular.
R.
Re: Gear Vendored 727 and a sure grip [Re: dogdays] #1277430
08/02/12 04:05 PM
08/02/12 04:05 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Not necessarily true...the weak part of any aluminum planetary is the spline, not the pinion count.
Re: Gear Vendored 727 and a sure grip [Re: John_Kunkel] #1277431
08/02/12 06:33 PM
08/02/12 06:33 PM
dogdays Offline
dogdays  Offline
Well, you know a heck of a lot more than I do about this, that's for sure. But isn't it true that regular TFs got 3 pinions, Motorhomes and some HP engines got 4 pinions, and Hemis got 5?
My DC Chassis books are packed away so I can't check.
R.
Re: Gear Vendored 727 and a sure grip [Re: dogdays] #1277432
08/02/12 06:44 PM
08/02/12 06:44 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
R.
I'm thinking your confusing clutch count vice pinon count in the trans.
Pretty sure anything more than a 3 pinion is an aftermarket deal on a 727.
Don't be the exception.
Re: Gear Vendored 727 and a sure grip [Re: John_Kunkel] #1277433
08/02/12 06:46 PM
08/02/12 06:46 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
I have a 727 equipped GV behind my 511 stroker. My 727 has the three pinion gear, bolt in sprag and a reverse manual VB. I also run a Dana. I have had no problems with my set up.
Re: Gear Vendored 727 and a sure grip [Re: John_Kunkel] #1277434
08/03/12 01:33 AM
08/03/12 01:33 AM
Downtown Roebuck Ont
Twostick Online content
Still wishing...
Twostick  Online Content
Still wishing...
My trans guy used to race a AA/SS Hemi Cuda and they used to take out 2 of the 4 pinions to reduce rotating weight. Never broke a pinion but splines?...
Kevin
Re: Gear Vendored 727 and a sure grip [Re: Supercuda] #1277435
08/03/12 03:42 PM
08/03/12 03:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
4-pinion planetaries are common in many '67 and later 727's; 5-pinion planetaries first appeared in the diesel OD.
