Re: new Moparts fastest car list, post yours!
[Re: Chuck@Best_Machine]
#12754
11/07/04 08:11 PM
11/07/04 08:11 PM
---7 second zone --- 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed
---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF
---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH
---10 second zone--- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Duster John 10.22 @ 131.76 1.44 60 ft. 73 duster,3400 lbs ,493 on pump gas, mufflers and 10.5 tires Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121
---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft
---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
#12756
11/07/04 08:36 PM
11/07/04 08:36 PM
---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
#12757
11/07/04 08:53 PM
11/07/04 08:53 PM
Posts: 344 Burlington, Ontario Canada
Dave_S
---10 second zone--- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Duster John 10.22 @ 131.76 1.44 60 ft. 73 duster,3400 lbs ,493 on pump gas, mufflers and 10.5 tires Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121
Dave Stillie '73 Swinger 5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4 Mega-Squirt EFI [email]8.93@149 [/email]
#12758
11/08/04 07:15 PM
11/08/04 07:15 PM
Posts: 10,018 Frostbitefalls MN (Rocky&Bullw...
gregsdart
---7 second zone --- 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
Post deleted by Defbob
[Re: gregsdart]
#12759
11/08/04 08:22 PM
11/08/04 08:22 PM
#12760
11/09/04 12:53 AM
11/09/04 12:53 AM
Posts: 1,278 Mission BC
10sec440
Mission BC
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed
---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF
---10 second zone--- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121
[Re: 10sec440]
#12761
11/09/04 01:04 AM
11/09/04 01:04 AM
Posts: 1,170 Westbury, NY
bumps440
super gas
super gas
Westbury, NY
Quote: ---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.84@124.4 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
[Re: bumps440]
#12762
11/09/04 10:59 PM
11/09/04 10:59 PM
Dave_S
---10 second zone--- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121
[Re: Dave_S]
#12763
11/13/04 03:21 AM
11/13/04 03:21 AM
Posts: 2,070 Taylor, Michigan
1BadLiLCharger
Taylor, Michigan
---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH
[Re: 1BadLiLCharger]
#12764
11/13/04 10:21 PM
11/13/04 10:21 PM
Posts: 17,925 Akron, Ohio
ProSport
Akron, Ohio
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
[Re: ProSport]
#12765
11/14/04 12:45 AM
11/14/04 12:45 AM
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 -------------------- 73' Dart Sport street/strip car, 10.18 at 130, 1.39 60 ft!
#12766
11/14/04 06:33 PM
11/14/04 06:33 PM
Posts: 1,397 Toronto Ontario, Can
Glen440
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
87 dakota 6.1 hemi
[Re: Glen440]
#12767
11/14/04 08:41 PM
11/14/04 08:41 PM
Posts: 16,932 NC
440Jim
NC
I finally figured out what was holding the new combo back. Today, in mine shaft air, I ran 9.692 at 136.2 mph, 1.326 sixty foot!---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
[Re: 440Jim]
#12768
11/14/04 10:35 PM
11/14/04 10:35 PM
Posts: 13,393 Marion, South Carolina [><]
an8sec70cuda
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. a10sec70cuda, 10.49@127.6 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
[Re: an8sec70cuda]
#12769
11/16/04 02:12 PM
11/16/04 02:12 PM
Posts: 872 Charlotte NC
DCI
Charlotte NC
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker DCI, 38 Simca 225ci Slant 6/904, 1/4 9.85@132.2mph, 1/8 6.10@109.8mph, 2315#, Turobcharged 12# of boost EFI on Methanol Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. a10sec70cuda, 10.49@127.6 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block."
Those words must have left a bad taste in his mouth!
[Re: DCI]
#12770
11/16/04 09:27 PM
11/16/04 09:27 PM
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension sloride, 9.43@126 shutoff @1000ft.testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99@136 on motor MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker DCI, 38 Simca 225ci Slant 6/904, 1/4 9.85@132.2mph, 1/8 6.10@109.8mph, 2315#, Turobcharged 12# of boost EFI on Methanol Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. a10sec70cuda, 10.49@127.6 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
Re: new Moparts fastest car list, post yours!
#12771
11/18/04 09:56 PM
11/18/04 09:56 PM
an8sec70cuda
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension sloride, 9.43@126 shutoff @1000ft.testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99@136 on motor MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker DCI, 38 Simca 225ci Slant 6/904, 1/4 9.85@132.2mph, 1/8 6.10@109.8mph, 2315#, Turobcharged 12# of boost EFI on Methanol Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs a10sec70cuda, 10.40@129.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
[Re: an8sec70cuda]
#12772
11/19/04 02:04 PM
11/19/04 02:04 PM
Posts: 1,118 Central Missouri - USA
Ramcharger
super gas
super gas
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension sloride, 9.43@126 shutoff @1000ft.testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99@136 on motor MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker DCI, 38 Simca 225ci Slant 6/904, 1/4 9.85@132.2mph, 1/8 6.10@109.8mph, 2315#, Turobcharged 12# of boost EFI on Methanol Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs a10sec70cuda, 10.40@129.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas mopar65 10.59@124, 1.45 60', 65 Plymouth 3500# 446 w/E heads RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop) '99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54 '89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift '14 Dodge Dart Limited 2.4/6-speed A/T
[Re: Ramcharger]
#12773
11/22/04 12:13 AM
11/22/04 12:13 AM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
---7 second zone --- Hemifred turbo Road Runner 7.21 2 193 1.11 60' 572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60' valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed ---8 second zone --- The Haze 8.02 @ 174+ twin turbo 452" B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60' SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only. JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164 W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161 TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340# SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A "Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156 Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04 Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60' RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF ---9 second zone --- Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph 572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car ! BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin 1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142 Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension sloride, 9.43@126 shutoff @1000ft.testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99@136 on motor MR P BODY 9.47@142.5 395 ci W-2 2430# Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142 440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137 Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89 Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker DCI, 38 Simca 225ci Slant 6/904, 1/4 9.85@132.2mph, 1/8 6.10@109.8mph, 2315#, Turobcharged 12# of boost EFI on Methanol Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99 DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH ---10 second zone--- Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400 Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A. ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#. J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60 Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam 10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs a10sec70cuda, 10.40@129.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5" StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor. daron 73 duster 10.50 et @ 127.00 sb street car BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas mopar65 10.59@124, 1.45 60', 65 Plymouth 3500# 446 w/E heads RVA 10.64@124.50 1.49 60' 440ci 3165lbs TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust eeka440 73 Swinger 446 906's auto 10.68@127.38 85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off) Mopartony, 68 Dart 470cid, 727, 10.89@121 ---11 second zone --- Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60' fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60' TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears... 440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street 68DART360 11.75 @ 113 1.57 60ft pump gas street tires 493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57 68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires 6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52 Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft ---12 second zone --- cudadan, 12.02 at 110 with a 1.58 60ft Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60' quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4 Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4 67Charger, 12.85 @ 105.43, 1.82 60', '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
