Page 7 of 25 1 2 5 6 7 8 9 24 25
Re: new Moparts fastest car list, post yours! [Re: Chuck@Best_Machine] #12754
11/07/04 08:11 PM
11/07/04 08:11 PM
---7 second zone ---
572stealth '92 Dodge Daytona 572 B1MC, torqueflight, 2330lbs. 7.68 @ 179.31mph, 1.08 60'
valiant65, 65 Valiant, 7.91 @ 181, 1.27 60ft, #3319, twinturbo 353B1BA + lenco 5-speed
---8 second zone ---
The Haze 8.02 @ 174+ twin turbo 452"
B1 Ken, '88 T-Bird, 2430#, 511 B-1 w/ Glide 8.178 @ 167.12 mph, 1.139 60'
SG303, 91 Daytona, 8.180 @ 165, 2420# 572 single 4, glide, just motor
Rapid588 93'Dodge Stealth, 8.24et 163mph, 1.15/60' ,2490lb, motor only.
JoeZ, 1972 Challenger, 451 B1 Nitrous, 727, 10.5" tire, 3005 lb, 8.36 @ 164
W8Duster, '71 Duster, 430 W8, single stage fogger, 'Glide, 29x10.5 (non W), 3350#, 8.57 @ 161
TwinDick Racing 73 Duster, 528, B1, Nitrous, Turbo 400, 10.5w 8.62 @ 157 3340#
SB412DUSTER 72 Duster 8.62 @ 156.4-1/4 - 5.33 @ 126.9-1/8-1.18 60' 4link B/half 2424lb 412/W7 NO P/A
"Tazmaniac" 1971 Challenger, 500 B1, Powerglide, 2650# 8.68 156
Gregsdart 65 dart 8.77et 153.16mph,528cu 440-1, 3000 lbs, 528 cu, 440-1heads, 2780 den altitude. NA 6/26/04
RT540, 69 Coronet, 8.908et 150.40mph, 1.245(60), 2840lbs, 540"B1BS-727TF
---9 second zone ---
Beeracuda 74 Barracuda 9.189 145.66 mph@4241' DA 2750 lbs 499/PG
NHRAMARK 70 Duster 3050 lbs, 540" Indy, 9.274 @ 145.76mph
572charger 3850lbs/ 9.27 at 144.50 pumpgas/ 10.5street tires /4 1/2 " exhaust w/tail pipes/ 125 hp shot on leaf springs/ driven daily / not a race car !
BEST MACHINE 65 Coronet 3460lbs 511,B1BS,10.5W,3.5"X pipe w muffs 9.29@143.8 1.27 60' All Motor and Foot Brakin
Bad66 '66' Dart GT,9.35@144.66,471 B1 stroker...,all throttle no bottle
TheOtherDodge, 9.39@144.91, 498, Auto, 3450 lbs, true 10.5 tires, through the mufflers on stock suspension
MR P BODY 9.47@142.5 395 ci W-2 2430#
Biginchmotor,72 Barracuda, 3,000 pounds, 500 inch motor, 727 auto no trans brake, super stock springs, 4.30 gear, 9.59 @ 142
acme383, 70 roadrunner, 493, jerico 4-speed, 3490#, 10.5 tire, 9.81@137
Mopargilley 68 Barracuda 400" W-2 motor 3170lbs stock 727 W/brake 4:56gear 11.5 tire 9.82 @ 135.89
440Jim '69 Dart 9.83et 134. mph, 3150lbs, all motor, 471CID
Bigcube '69 Dart 9.87et 138 mph, 2950lbs, all motor, 11:1comp 476cid
b3422w5, 70 duster,422w5,3380lbs,727,leafs..9.94 at 133.99
DavidDean, 71 Duster 9.96@134 5500'DA 413" 904 SB 2850 lbs 6.18 @ 109 1/8 3500'DA
Sleepyhead416 1.350 60FT 9.972 E.T 131.56 MPH
---10 second zone---
Tig '74 Challenger, 10.13@135.2 1.506 60ft, 528ci, Indy -13 heads, 3916lb W/D, N/A.
J-BODY 80 Mirada 10.18 @ 130.5 1.39 60ft 498 Stage VI heads 3380lb
Clutch 88 D100 512ci 10.22@132.37 NA 1.498 60
Duster John 10.22 @ 131.76 1.44 60 ft. 73 duster,3400 lbs ,493 on pump gas, mufflers and 10.5 tires
Marvo451 '71 Duster 10.23@130.50,1.41/60ft.,451 RB. Iron 452 heads, pump gas, flat tappet cam
StrokerPost 67 Dart Sedan, 414 SB, 10.45 @ 127, 3290lbs, factory iron heads, all motor.
daron 73 duster 10.50 et @ 127.00 sb street car
BB70DUSTER, 10.52 at 130 mph,400 stock bottom end w/ E heads on squeeze, and on pump gas
a10sec70cuda, 10.55@128.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5"
RVA 10.64@124.50 1.49 60' 440ci 3165lbs
TimMoffett 69 Charger 4-speed Street Car 10.68 @ 128.3, 1.54 60', 3900Lbs with full exhaust
eeka440 73 Swinger 446 906's auto 10.84@124.4
85 Camaro SB 385cid 3380Lbs P/Windows all steel street legal & driven 10.86@118 (let off)
Mopartony, 68 Dart 470cid, 727, 10.89@121
---11 second zone ---
Bubba '80 Mirada, 440 , 11.10 & 121.34, 1.54 60', 3855LBS
ZIPPY '69 GTX Street Car, 451CI, 11.24 @ 119.3, 1.58 60'
fast68plymouth, 68 Satellite, 383, 3675lbs, 11.26 @ 119, 1.51 60'
TC67CUDA 11.30 @ 118.98 1.60 60' 440 346heads 727 thru mufflers 3400 lbs w/driver street tuned
Mark Gates 11.317@120.209, 1.542 60', 7.17 1/8, iron head 451/727/3.91 8 3/4 #3765 AMC Pacer
LAR_414 1969 Dart GT 11.33 118.9mph 3350lbs race wt 1.60 60' 414 stroked smallblock w/ factory J heads, solid cam and pump gas
aarlucas '70 cuda,11.40 @ 121.80 W/1.63 60',451"6 PK, 3680lbs,2.5"exh sys,pump gas, 3.91, auto
w2_360duster 11.40 @119.18 375 ci w2 no nos thru mufflers @ 3000 ft alt. 3020lbs w/o driver
tboomer '64 Dodge 330 sedan,3460# 446" 11.708,60' 1.674 114.24 3.91 gears...
440Jim '73 Cuda 11.72et 113mph, 3700lbs, hyd cam, 446CID, street
68DART360 11.75 @ 113 1.57 60ft pump gas street tires
493Charger 68 Charger R/T auto. 493" 3750 LBS 1.65 60' 11.76 116.57
68LAR '68 Road Runner 11.85ET 116.6MPH 3926LBS 1.65 60' 4 SPEED street car
Sledgehammer '71 Dart Swinger 11.78ET 114MPH 3470LBS 366ci J-headed Small Block 904 Auto on street tires
6PKBEE 11.877 Aspen R/T 360/904/3.91 60'@ 1.59 @112.52
topfueldart 70 challenger 446, bone stock 906's, hyd cam, 11.97 @ 111 1.65 60ft
---12 second zone ---
cudadan, 12.02 at 110 with a 1.58 60ft
quickd100, 1.595 60ft. 7.621@87.04-1/8 12.19@105.88 1/4
Jon Smith 69 charger 493" full street trim 1.88 60 ft 7.94@90 1/8 12.305@112 1/4
Re: new Moparts fastest car list, post yours! #12755
11/07/04 08:34 PM
11/07/04 08:34 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
can someone put mine in for me??
Re: new Moparts fastest car list, post yours! #12756
11/07/04 08:36 PM
11/07/04 08:36 PM
Mikesduster-72 duster,340,street trim,12.07@108, 1.72 60'
Re: new Moparts fastest car list, post yours! #12757
11/07/04 08:53 PM
11/07/04 08:53 PM
Burlington, Ontario Canada
Dave_S Offline
Dave_S  Offline
eeka440 73 Swinger 446 906's auto 10.68@127.38
Dave Stillie
'73 Swinger
5.7 Hemi, 88mm turbo, powerglide, cal-tracs & 8 3/4
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: new Moparts fastest car list, post yours! [Re: Chuck@Best_Machine] #12758
11/08/04 07:15 PM
11/08/04 07:15 PM
gregsdart Offline OP
quickd100, 1.595 60ft. 7.621@87.04-1/812.19@105.88 1/4
Post deleted by Defbob [Re: gregsdart] #12759
11/08/04 08:22 PM
11/08/04 08:22 PM
Re: new Moparts fastest car list, post yours! #12760
11/09/04 12:53 AM
11/09/04 12:53 AM
Mission BC
10sec440 Offline
10sec440  Offline
Mission BC
Hemifred turbo Road Runner 7.21 2 193 1.11 60'
Hemifred SOX&MARTIN DUSTER 8.781 @155.13 1.261 60'
10sec440- 10.24@128- 1.36/60 440RB 452 heads 590cam pump gas 3400lbs
Re: new Moparts fastest car list, post yours! [Re: 10sec440] #12761
11/09/04 01:04 AM
11/09/04 01:04 AM
Westbury, NY
bumps440 Offline
super gas
bumps440  Offline
super gas
Westbury, NY
Bumps440. 69GTX 9.84et 134.90 MPH 3240lbs, all motor, 446ci, stageIV iron heads, Footbraker
Re: new Moparts fastest car list, post yours! [Re: bumps440] #12762
11/09/04 10:59 PM
11/09/04 10:59 PM
Dave_S Offline
Dave_S  Offline
Dave Stillie
'73 Swinger
Mega-Squirt EFI
[email]8.93@149
[/email]
Re: new Moparts fastest car list, post yours! [Re: Dave_S] #12763
11/13/04 03:21 AM
11/13/04 03:21 AM
Taylor, Michigan
1BadLiLCharger Offline
Taylor, Michigan
1BADLILCHARGER '81 Charger 2300lbs., 440/727w/brake, Eddys, 1.23 60ft, 9.33 @ 142
Re: new Moparts fastest car list, post yours! [Re: 1BadLiLCharger] #12764
11/13/04 10:21 PM
11/13/04 10:21 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
ProSport- '73 Dart Sport, 10.18 and 132.45 MPH, 1.394 60 ft, 451 with E-heads & MP 590 cam, 3,035#.
Re: new Moparts fastest car list, post yours! [Re: ProSport] #12765
11/14/04 12:45 AM
11/14/04 12:45 AM
Duster John 73 duster 1.39 60ft, 6.40 @ 107.90 1/8, 10.05 @ 133.59 street car pump gas, mufflers, 10.5"tires,#3400
73' Dart Sport street/strip car, 10.18 at 130, 1.39 60 ft!
Re: new Moparts fastest car list, post yours! #12766
11/14/04 06:33 PM
11/14/04 06:33 PM
Toronto Ontario, Can
Glen440 Offline
Glen440  Offline
Glen440 77 Volare 440/727/4.10 60' 1.62 11.90@111.6
87 dakota 6.1 hemi
Re: new Moparts fastest car list, post yours! [Re: Glen440] #12767
11/14/04 08:41 PM
11/14/04 08:41 PM
NC
440Jim Offline
440Jim  Offline
NC
I finally figured out what was holding the new combo back. Today, in mine shaft air, I ran 9.692 at 136.2 mph, 1.326 sixty foot!
440Jim, '69 Dart GTS, 3120 lbs, 471 CID, 9.692 at 136.2 mph, 1.326 60ft ALL MOTOR
Re: new Moparts fastest car list, post yours! [Re: 440Jim] #12768
11/14/04 10:35 PM
11/14/04 10:35 PM
an8sec70cuda Offline
a10sec70cuda, 10.49@127.6 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5"
CHIP
'06 GMC 2500HD LBZ Duramax
Re: new Moparts fastest car list, post yours! [Re: an8sec70cuda] #12769
11/16/04 02:12 PM
11/16/04 02:12 PM
Charlotte NC
DCI Offline
DCI  Offline
Charlotte NC
DCI, 38 Simca 225ci Slant 6/904, 1/4 9.85@132.2mph, 1/8 6.10@109.8mph, 2315#, Turobcharged 12# of boost EFI on Methanol
"Turbo will be easiest, and at the HP level will also be easiest on parts. Spend the money to do it right, and you can build a 500 HP street motor that will live a long and happy life, and probably with a very basic short block." Those words must have left a bad taste in his mouth!
Re: new Moparts fastest car list, post yours! [Re: DCI] #12770
11/16/04 09:27 PM
11/16/04 09:27 PM
sloride, 9.43@126 shutoff @1000ft.testing 70 cuda 572 indy head 3500# street trim w/225 shot, 9.99@136 on motor
Re: new Moparts fastest car list, post yours! #12771
11/18/04 09:56 PM
11/18/04 09:56 PM
a10sec70cuda, 10.40@129.1 mph, 446 cid, 3700 lbs, all motor street car, through mufflers on 10.5"
CHIP
Re: new Moparts fastest car list, post yours! [Re: an8sec70cuda] #12772
11/19/04 02:04 PM
11/19/04 02:04 PM
Central Missouri - USA
Ramcharger Offline
super gas
Ramcharger  Offline
super gas
mopar65 10.59@124, 1.45 60', 65 Plymouth 3500# 446 w/E heads
'64 Dodge 440 2 dr. sedan - 440/pushbutton 727 (in the body shop)
'99 Dodge 2500 Quad Cab Long bed 4WD - CTD 5 spd. 3.54
'89 Dodge 150 4x4 - 5.9 TBI/727 35x12.50's and 8" lift
'14 Dodge Dart Limited 2.4/6-speed A/T
Re: new Moparts fastest car list, post yours! [Re: Ramcharger] #12773
11/22/04 12:13 AM
11/22/04 12:13 AM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
67Charger, 12.85 @ 105.43, 1.82 60', '67 Charger, 440/727 (full man.), 4.10's, 3750# w/ me
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
