Best B or RB dual quad intake? #1275112
07/27/12 09:56 PM
07/27/12 09:56 PM
jersey
Spaceman Spiff Offline OP
jersey
Whats the best B or RB dual quad inline intake, that still looks kinda stock( no tunnel rams or crazy box intakes)
I'm asking because:
I'd like to put together a F.A.S.T. Like car. Not adhering to the rules to race, but something that looks close to a factory engine.
Here's my idea. Since '58 was the first year for the big block, i'd like to build a 500ish inch stroker. Stealth heads or really good ported irons. Cam will be spec'd by the head ported to match the combo. I'll use HP manifolds, that will have porting/extrude honing.
The holdback is the induction system. The 350 golden commando was dual quad only in '58, so i need a good intake. I'll grind off markings and paint tom match the engine. This engine was an option in any plymouth in '58 from the low line four door plaza, to a station wagon, and Fury.
So what's a really good intake to use? It doesn't have to be a low profile look, it can be raised like a performer rpm style. As long as once painted with the engine it passes for "close" That'll do.
Most likely will be using a 2 door sedan, for weight savings and rigidity.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Best B or RB dual quad intake? [Re: Spaceman Spiff] #1275113
07/27/12 10:23 PM
07/27/12 10:23 PM
Ohio, USA
Dr-Dave2 Offline
Dr-Dave2  Offline
Ohio, USA
not too many choices with what you are trying to do. Edelbrock CH-28 is all I know of thats any good and still in production, (RB only)
http://www.summitracing.com/parts/EDL-5440/
I would stay away from the Offenhauser offerings for a performance application
Re: Best B or RB dual quad intake? [Re: Spaceman Spiff] #1275114
07/27/12 11:10 PM
07/27/12 11:10 PM
AndyF Offline
AndyF  Offline
I have a tech article on my website with some CH-28 test results. That intake worked pretty well on a 505 inch stroker.
www.arengineering.com then click on the tech articles section
Re: Best B or RB dual quad intake? [Re: AndyF] #1275115
07/27/12 11:50 PM
07/27/12 11:50 PM
ill
dennismopar73 Offline
ill
M1 (Mopar Performance) if you can find one!!
Re: Best B or RB dual quad intake? [Re: dennismopar73] #1275116
07/28/12 01:32 AM
07/28/12 01:32 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
CH-28 is the only decent performing dual quad intake I can think of for what you want to do.
Re: Best B or RB dual quad intake? [Re: DaytonaTurbo] #1275117
07/28/12 05:56 AM
07/28/12 05:56 AM
Cincinnati OH
Bishop Offline
Bishop  Offline
Cincinnati OH
Surf over to Mopar Style and look at the results from there test, a Edelbrock STR 14 & 15 has took their car into the 9's WITH a modified intake.
Brian
Re: Best B or RB dual quad intake? [Re: Spaceman Spiff] #1275118
07/28/12 10:26 AM
07/28/12 10:26 AM
New York
polyspheric Offline
polyspheric  Offline
New York
No direct experience, but Vizard has tested some 2×4 dual-planes on SBC and reported very significant differences in flow rates between cylinders.
Has anyone tested the CH28?
Boffin Emeritus
Re: Best B or RB dual quad intake? [Re: polyspheric] #1275119
07/28/12 10:39 AM
07/28/12 10:39 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Some may recall...............
Don Dulmage, a freelance writer for Chrysler Power (anyone remember that? Good reading.) ran a 73-74 440 Charger bracket car back in the early 90's or so with a CH-28. He wrote some good things about it, can't remember specifics but I would like to try one some day.
Re: Best B or RB dual quad intake? [Re: Spaceman Spiff] #1275120
07/28/12 12:28 PM
07/28/12 12:28 PM
Canada
CrAzYMoPaRGuY Offline
Canada
My Jensen Interceptor runs a 440 with a CH28 and two Edelbrock 500 carbs. Runs flawlessly, pulls HARD top end, great low end torque, and it even gets good gas mileage. NO drawbacks IMO.
My Charger also has a CH28 intake, but it has two Edelbrock 600s on it, it also runs great, but I haven't finished tweaking it as it has an "off spot" from time to time, slight hesitation when pounding it from a very low rpm. It's close to being 100%, but not quite yet...
I have just bought another CH28 intake, and two more Edelbrock 500 carbs. I have a warmed over 440 with a decent cam and headers, and will convert to dual quads in the fall.
It's for my...... motorhome.
CrAzYMoPaRGuY
Re: Best B or RB dual quad intake? [Re: polyspheric] #1275121
07/28/12 12:45 PM
07/28/12 12:45 PM
AndyF Offline
AndyF  Offline
No doubt the flow rate between cylinders is significant. But when we did the dyno tests on the 505 engine the CH-28 worked really well. Idle quality was fantastic. Torque curve looked good, EGT's in all 8 cylinders looked normal, plugs looked good, etc.
My recommendation would be to just run it a little rich to be safe. Unless you put an O2 sensor in each header pipe you won't know for sure. Even then, you would probably have trouble fixing the issue.
