How to remove gasket goop from rear window trim? #1274827
07/27/12 09:44 AM
07/27/12 09:44 AM
PA
dodgeman316 Offline OP
PA
Anyone have experience with cleaning the black window sealant goop from the rear stainless trim?
I saw a post which indicated WD40 may work but it didn't seem to do much.
1969 Super Bee
Re: How to remove gasket goop from rear window trim? [Re: dodgeman316] #1274828
07/27/12 11:01 AM
07/27/12 11:01 AM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
Fluid Film works great! Put it on the goop, let it soak in a few hours or a night and wipe off the mess with a dry towel.
http://www.fluid-film.com/products/
Re: How to remove gasket goop from rear window trim? [Re: dodgeman316] #1274829
07/27/12 12:05 PM
07/27/12 12:05 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
I used Omni MS-251 spray gun cleaning solvent. You can get it from your PPG auto paint store or other brands may have a similar product ( Spray gun cleaning solvent). You will need plenty of rags or shop towels but it takes it right off.
Re: How to remove gasket goop from rear window trim? [Re: GreenGlow] #1274830
07/27/12 12:43 PM
07/27/12 12:43 PM
Lakewood, Colorado
runnerrt Offline
runnerrt  Offline
Lakewood, Colorado
Put mine in the solvent tank at work. Pointed the hose in the direction I needed and let it run down the trim. An hour later no goop.
1969 Super Bee High School car I got back 2004 Ram 2500
Re: How to remove gasket goop from rear window trim? [Re: runnerrt] #1274831
07/27/12 05:21 PM
07/27/12 05:21 PM
PA
PA
Thanks for the replies.
Any thoughts on lacquer thinner?
It seems to be pretty potent stuff...
Would it play nice with the stainless?
1969 Super Bee
Re: How to remove gasket goop from rear window trim? [Re: dodgeman316] #1274832
07/28/12 11:03 AM
07/28/12 11:03 AM
Amherst,NY
challengermike Offline
Amherst,NY
thinner or reducer will work.
Re: How to remove gasket goop from rear window trim? [Re: challengermike] #1274833
07/28/12 02:37 PM
07/28/12 02:37 PM
IN
ahy Offline
ahy  Offline
IN
Strong solvents won't bother the stainless. I've tried lacquer thinner before. It works but not as well as adhesive remover or paint stripper. I'd just goop them up with remover and let sit for a while. It all should wipe off.
