YEAR ONE WIRING HARNESS #1274253
07/26/12 12:59 AM
07/26/12 12:59 AM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Getting ready to reinstall the old wiring harness in my 69 Charger, and was thinking about getting new one's from year one. Wondering who all has replaced their wiring harness from year one? were you happy with the results and connections?
Re: YEAR ONE WIRING HARNESS [Re: JohnH] #1274254
07/26/12 01:03 AM
07/26/12 01:03 AM
Itasca, Texas
Mad_Scientist Offline
Itasca, Texas
I replaced my interior harness with a YO. It seemed like a nice piece to me. I didn't see any issues with the wiring or connectors. Others may have had different experiences. I did modify the harness to cut the amp guage out and upgraded some of the wiring to a bigger guage, but that was only because my car is far from stock.
69 Super Bee 440 5-speed
70 Dart Swinger 340 4-speed
69 Camaro SS 396 4-speed
66 Cutlass Convertilbe
70 Judge Ram Air III 4-speed
68 F-100 SWB
Re: YEAR ONE WIRING HARNESS [Re: JohnH] #1274255
07/26/12 02:51 AM
07/26/12 02:51 AM
fiddlerfingers Offline
I replace my entire harrness system in my 71 RR and every harrness was spot on. It was all plug n play no mods needed.
Re: YEAR ONE WIRING HARNESS [Re: fiddlerfingers] #1274256
07/26/12 05:27 AM
07/26/12 05:27 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
Year One carries M&H afaik. From what I understand, they are the best. I did get a harness or two from Evans, and they were good, as well, and normally are at the Nationals, if you wanted to pick one up there.
I don't think they do dash harnesses, though.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: YEAR ONE WIRING HARNESS [Re: OhioMopar] #1274257
07/26/12 08:02 AM
07/26/12 08:02 AM
Missouri
68KillerBee Offline
68KillerBee  Offline
Missouri
I replaced mine earlier this year (underdash harness) on my super bee. Had no problems at all with it. Also had my engine bay one from evans a few years back when I switched to electronic ignition, once again no problems.
Just buy the harness using one of the discount codes. Its in a thread under the "hot deals and new products". There is a 20% off deal going right now.
Re: YEAR ONE WIRING HARNESS [Re: 68KillerBee] #1274258
07/26/12 10:52 AM
07/26/12 10:52 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I bought every harness that Year One listed for my car. The only thing I had to reuse was the radio harnesses and Rallye "light group" harnesses. Everything else is new.
The tail light bulb sockets were a little different then the original ones. The main alternator wiring insulator was a rubber piece instead of the stock hard plastic. And the insulation around the horn wires was different but other then that, they fit just fine.
I made sure to double check the connections and cross referenced the wires between the old and new harnesses. I hooked a battery up to the car last month and everything works.
Re: YEAR ONE WIRING HARNESS [Re: JohnH] #1274259
07/30/12 02:58 PM
07/30/12 02:58 PM
Iowa
GreenBird Offline
GreenBird  Offline
Iowa
69 Road Runner. I installed all new harnesses from YO (made by M&H) and everything works. Wires are the correct colors for using original schematics. Only thing that surprised me was the under dash harness includes a fuse box that uses glass fuses, I guess to be true to the original.
Re: YEAR ONE WIRING HARNESS [Re: GreenBird] #1274260
07/30/12 08:08 PM
07/30/12 08:08 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
Thanks for all your replys... New wires on order...
