powerglide questions
#1273999
07/25/12 09:31 PM
07/25/12 09:31 PM
Posts: 508 mt.ephraim , new jersey
jsmopar1072
we have a 2800 lbs car roughly 825hp,i have a 50/50 reaction on what trans to use for racing.some say just put a 727 in it and hope for the best,others say i need a glide with an aluminum case which wont fit in an abody without cutting tunnel.next thing is who builds glides in the delaware valley area.
WINNING IS ALL LUCK,ASK ANY LOSER!
OBJECTS IN MIRROR APPEAR TO BE LOSING!
JEFF'S BUDGET DODGE GARAGE!!!!
Re: powerglide questions
[Re: jsmopar1072]
#1274001
07/25/12 09:59 PM
07/25/12 09:59 PM
Posts: 6,341 Heaven
EvilB1Dart
Heaven
who told you that? that's incorrect info.
[Re: EvilB1Dart]
#1274003
07/25/12 10:02 PM
07/25/12 10:02 PM
jsmopar1072
joey d have an address and i wrote it wrong i meant a stock glide case with a sheild.
[Re: jsmopar1072]
#1274013
07/26/12 12:44 AM
07/26/12 12:44 AM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Silly stuff..
No cutting, and a Bruno or CSR shield will work fine..
My B1 3000# Barracuda runs 8.80's @ 152+ 3500' DA bad air here in Phoenix with a 9" converter and a 4.10 gear..
But it will go red on a .400 tree also with a soft converter..
Never broke a stock glide input or gear set.
Did break a 1.96 TCI gear set once..
You probably shouldn't listen to die hard "gotta run all Mopar" guys..
They'll give you a headache..
Chris..
[Re: jamesc]
#1274015
07/26/12 06:45 AM
07/26/12 06:45 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
James, I have had great success getting consistency out of my TF, and if a guy is struggling in the 60 ft he can always take some gear out of it. I do have to admit that I use an airshifter, so having that being part of my success with consistency both of your points are valid to some degree. 440JIM has been killer with a torqueflite, and done very well with it.
