1973 400 4bbl kick down linkage - what's it look like? #1273986
07/25/12 08:53 PM
07/25/12 08:53 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
I have some kick down linkage from a '73 400 2bbl & the parts catalog shows different bracket & rod for 400 4bbl and other part#s for 440.
What's the difference? Anyone got pics? What's the non-A/C throttle return spring bracket look like?
Re: 1973 400 4bbl kick down linkage - what's it look like? [Re: 6bblgt] #1273987
07/26/12 01:03 PM
07/26/12 01:03 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
anyone?
Re: 1973 400 4bbl kick down linkage - what's it look like? [Re: 6bblgt] #1273988
07/26/12 01:57 PM
07/26/12 01:57 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The 4-barrel carb throttle lever sits further forward than the 2-barrel so the top link is longer. Also, the 440 block is taller than the 400 so the rod is shaped differently.
Re: 1973 400 4bbl kick down linkage - what's it look like? [Re: John_Kunkel] #1273989
07/26/12 03:00 PM
07/26/12 03:00 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
The '73 Parts catalog shows the LINK (14-11-18) to be the same 400 2bbl/400 4bbl/440 4bbl B & C-body - part #3671 708.
It also shows the STABILIZER (14-11-55) to be the same 400 2bbl/400 4bbl/440 4bbl B & C-body - part #3418 807.
BRACKET (14-26-6) any tips to ID one from the other?
400 2bbl #3418 810
400 4bbl #3577 550
440 4bbl #3577 553
ROD (14-11-9) any tips to ID one from the other?
400 2bbl #3462 760
400 4bbl #3577 555
440 4bbl #3577 556
Someone have a STOCK '72-'73 400 440 Road Runner or Charger they could take a look at & comment?
Re: 1973 400 4bbl kick down linkage - what's it look like? [Re: 6bblgt] #1273990
07/26/12 03:02 PM
07/26/12 03:02 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Here's what I have - pretty sure top one is 400 2bbl
Re: 1973 400 4bbl kick down linkage - what's it look like? [Re: 6bblgt] #1273991
07/26/12 03:04 PM
07/26/12 03:04 PM
Las Vegas, NV
6bblgt Offline OP
6bblgt  Offline OP
Las Vegas, NV
Am I correct that the "spring loaded" transmission end of the rod started in '74?
Re: 1973 400 4bbl kick down linkage - what's it look like? [Re: 6bblgt] #1273992
07/26/12 07:08 PM
07/26/12 07:08 PM
Berwyn, IL
Moparlar Offline
Moparlar  Offline
Berwyn, IL
A lot of the rods have a part number stamped in them at the top. That might help you a little
Larry
