Help with 2000 LHS front end noise #1273973
07/25/12 07:47 PM
07/25/12 07:47 PM
Seed Corn Capital USA
jlemon Offline OP
jlemon  Offline OP
Front left makes a continuous grinding/scrapping noise but stops when the wheel is barely turned left or right. Just changed the wheel/hub bearing 2 weeks ago. Any ideas? Brake pads don't look that bad.
Re: Help with 2000 LHS front end noise [Re: jlemon] #1273974
07/25/12 07:51 PM
07/25/12 07:51 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Dust shield behind the rotor?
Re: Help with 2000 LHS front end noise [Re: Dcuda69] #1273975
07/25/12 08:08 PM
07/25/12 08:08 PM
jlemon Offline OP
jlemon  Offline OP
Just jacked it up and checked grabbed the tire at 9-3 to check for play and it has a LOT.
Re: Help with 2000 LHS front end noise [Re: jlemon] #1273976
07/25/12 09:27 PM
07/25/12 09:27 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I don't know about the 2000s, but check rack mount bushings, inner tie rod ends, engine cradle bushings, etc.
Re: Help with 2000 LHS front end noise [Re: jlemon] #1273977
07/26/12 01:55 AM
07/26/12 01:55 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Didn't put the proper torque on that new hub bearing?
Re: Help with 2000 LHS front end noise [Re: Jim_Lusk] #1273978
07/26/12 01:59 AM
07/26/12 01:59 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Sounds like it could be a front wheel bearing.
