Leaky MSD Coils. #1272787
07/23/12 06:25 PM
07/23/12 06:25 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Anybody have trouble with their Blaster 2 coil lately. I had one on my 69 Super Bee leak oil like crazy out the tower down the coil wire and into the distributor. We used to make these in Logansport IN at Federal Mogul but they sold the business and the buyers moved the manufacturing process to Mexico. They have a batch that weren't brought to 100c while adding the oil. This thing didn't leak it spewed when it got hot and expanded.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: Leaky MSD Coils. [Re: TimS] #1272788
07/23/12 06:33 PM
07/23/12 06:33 PM
Right here
HP2 Offline
HP2  Offline
Right here
I just replaced one I bought before 2004, it just started leaking. Found out when I should lift the intake...
70 W100 Power Wagon. 318 4-spd
70 Sport Fury 440 2dr HT
71 Duster 340
71 Charger Super Bee - 383/727
72 Charger "Sabotage" - 440/727 - Street/Strip
78 Warlock in beautiful patina
Re: Leaky MSD Coils. [Re: TimS] #1272789
07/23/12 06:34 PM
07/23/12 06:34 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i've had the same Blaster 2 for over 15 years, mounted sideways in a 6-pac setup and never had an issue. i would say the key phrase here is 'move to Mexico'! you might want to try their new e-coil (same design and spec's)but i can't remember what they are called off the top of my head.
Re: Leaky MSD Coils. [Re: TimS] #1272790
07/23/12 06:35 PM
07/23/12 06:35 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Bummer, I used to have one and it leaked and I trashed it like a long time ago.
Now I'm running a 35 dollar parts store coil which runs the same or better than the MSD.
Then a few weeks ago I swapped out a good working MP chrome ECU box for stock gold and black ECU that I had from 20 years ago and it runs noticablely better than the chrome box, I swear it does. Stock ECU and parts store coil and my car is running better than it has for years. I don't trust much from MP or even MSD nowadays.
Re: Leaky MSD Coils. [Re: TimS] #1272791
07/23/12 09:26 PM
07/23/12 09:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
There is a screw down in the tower tighten it.
Re: Leaky MSD Coils. [Re: Dodgem] #1272792
07/24/12 12:18 AM
07/24/12 12:18 AM
IN
ahy Offline
ahy  Offline
IN
The red ones are not recommended for horizontal mount... does that have anything to do with it? Mine's vertical and fine after 6 years or so.
Re: Leaky MSD Coils. [Re: ahy] #1272793
07/24/12 09:31 AM
07/24/12 09:31 AM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
I had a blaster coil a year ago that leaked the first time I started the car. The oil spoog came out of the top of the terminal where they forgot to solder the hole closed. Those teminals are hollow gee I wonder why we see so many posts about broken terminals?? They gave me another and it's been working fine. I don't drive the car very much but so far so good.
Re: Leaky MSD Coils. [Re: GreenGlow] #1272794
07/24/12 10:41 AM
07/24/12 10:41 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
for quite some time, they've had 2 types of coil. the oil filled ones, which it says right on the package, "do not mount horizontally" because the oil will leak out of them, they'll overheat and breakdown.
the other was epoxy filled, or at least epoxy sealed on the top, and were noticeably more expensive, these were ok to mount in any position you wanted.
sure you can call them a poor design, or say that quality has gone downhill with a shift in manufacturing location, but it's kind of hard to put blame on anyone but yourself when they tell you right in the instructions "Do not mount horizontally" and you chose to mount it horizontally...
**Photobucket sucks**
Re: Leaky MSD Coils. [Re: 70Cuda383] #1272795
07/24/12 01:59 PM
07/24/12 01:59 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
Mine is mounted verticle as it says in the instructions and it leaked out of the terminals. That kind of blows your theory out of the water.
Re: Leaky MSD Coils. [Re: 70Cuda383] #1272796
07/24/12 02:04 PM
07/24/12 02:04 PM
Arizona
GreenGlow Offline
GreenGlow  Offline
Arizona
This one is mounted verticle also and it's been fine for 2 years now. So I guess it's a 50/50 chance.
Re: Leaky MSD Coils. [Re: GreenGlow] #1272797
07/24/12 02:05 PM
07/24/12 02:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Had one MSD leak and the screw had come loose down in the tower. It's a spare now and checked my new one and screw needed tightening but not leaking yet! :-)
Wonder if you could loctite the screw??
Re: Leaky MSD Coils. [Re: GreenGlow] #1272798
07/29/12 08:10 AM
07/29/12 08:10 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Correct, verticality has nothing to do with it. It's the increased pressure of the oil pushing on the tower seal. When these are manufactured they are supposed to be heated to 100C with the oil in the coil,then when we at Federal Mogul made them in the good ole USA, had an automatic screw gun that installed the screw and fitting to tower, trapping the hot oil. The dudes in Mexico have evidently bypassed that process or just decided not to do it on this lot of coils. I did tighten the screw up to expand the seal. That may or may not work. I'm hoping it has lost enough oil that when it gets real hot again the seal won't see as much pressure, but hasn't lost enough to effect the electronic performance. 35 inch lbs for screw installation torque was more than enough for seal compression when the coil is processed properly.
