Caravan fuel pump question... #1269472
07/17/12 01:29 PM
07/17/12 01:29 PM
Missouri
bb74swngr Offline OP
mopar addict
mopar addict
Missouri
2005 Grand Caravan. Does anyone have a picture or know where on the top of the gas tank the fuel pump is located? I am being pro-active and need to get this accomplished because the pump is getting noisy. I would like to cut a hole in the floor of the van to access the fuel pump instead of dropping the tank. I could then fabricate a nice looking removable access cover for future issues. If I knew approximately where it was located I could keep the access hole size to a minimum. Is this just dumb or does it sound reasonable?
Russ:)
BigBlock 74 Swinger
Re: Caravan fuel pump question... [Re: bb74swngr] #1269473
07/17/12 02:09 PM
07/17/12 02:09 PM
P
Paul_Fancsali Offline
P
You will have to drop tank to cut the hole safely Why bother? Job easier done on rack but not really hard to do by any means
Re: Caravan fuel pump question... [Re: Paul_Fancsali] #1269474
07/17/12 08:44 PM
07/17/12 08:44 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
u would need to peek under there..on a 96-2000 vans the tank just has to drop about 1-2 inches to get to the unit...might be the same for yours ..google it....
Re: Caravan fuel pump question... [Re: bb74swngr] #1269475
07/17/12 10:11 PM
07/17/12 10:11 PM
Winnipeg, MB
sreinheimer Offline
sreinheimer  Offline
Winnipeg, MB
Those tanks are pretty easy to drop down. would be more work to cut a hole than its worth
69 Dodge Charger - first full resto 05 Dodge Magnum R/T
Re: Caravan fuel pump question... [Re: sreinheimer] #1269476
07/18/12 08:05 AM
07/18/12 08:05 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you have access to a hoist it would be a piece of cake. I changed the pump out in our '95 Grand Caravan on jackstands and it wasn't a big deal as I recall.
