2005 Grand Caravan. Does anyone have a picture or know where on the top of the gas tank the fuel pump is located? I am being pro-active and need to get this accomplished because the pump is getting noisy. I would like to cut a hole in the floor of the van to access the fuel pump instead of dropping the tank. I could then fabricate a nice looking removable access cover for future issues. If I knew approximately where it was located I could keep the access hole size to a minimum. Is this just dumb or does it sound reasonable?
Russ:)
