Re: Where to buy jets for older carter BBD
[Re: mrm82]
#1268747
07/16/12 07:13 PM
07/16/12 07:13 PM
RapidRobert
You'll likely have to locate several cores & see if one of them has a smaller jet(s). I'd think a later one (in the years they were used) would be leaner
[Re: mrm82]
#1268748
07/17/12 01:39 AM
07/17/12 01:39 AM
Posts: 124 Pittsburgh, PA
bigdaddywiz
Pittsburgh, PA
I have a older style carter 2 barrel BBD carb, model #6150SA, that im looking to buy a range of main jets for. The jets in the pic (if I attached it right) are the older stlye, that have a shank assy attached to the jet, with 4 holes in the bottom, that apear to be a guide for the metering rods. Anyone have these or any ideas where to get them at? All Im finding so far online is the newer style jets in the pic. Right now I have a 120-309S which too rich, thanks in advance for any help!
i still gotta find out where my dad went to get that bumper for the road runner...that guy might have extra carbs you can scrounge. but that was many moons ago...purple ones at that.
i didnt get a chance to see my dad today, so i'll check with him tomorrow and give you a call.
[Re: mrm82]
#1268749
07/17/12 10:47 AM
07/17/12 10:47 AM
Posts: 404 Central New York
bfury
Central New York
Here's an old school idea. Clean the jets, solder them closed and redrill them to what you need. Yeah I know, the flow may not be ideal but it doesn't sound like you're running a race car. Might be worth a try on some extra jets.
No Stock
[Re: bfury]
#1268750
07/17/12 11:15 AM
07/17/12 11:15 AM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
The older BBD's are air metered (like the '71 and older Thermoquads) VS the newer "tin top" solid fuel BBD's. Jet and rods don't swap. Newer BBD's are more adjustable on the travel of the metering rods.
IIRC there is some adjustment on the metering rod tree. That would be the Allen head screw. Notate where you start at so you can return.
What are you running this on?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: bfury]
#1268751
07/17/12 01:54 PM
07/17/12 01:54 PM
Posts: 4,951 northwest USA
NANKET
northwest USA
Good idea that will fail, the metering rod will wear the solder away when driving.
