Norwalk Mopar World FinalsII #1267126
07/13/12 09:24 PM
07/13/12 09:24 PM
North Eastern New York State
montessa Offline OP
montessa  Offline OP
I have been considering a field trip to Norwalk this fall and have a couple of questions. First, do they have the motor blanket requirement on cars running in the nines? Also, My car has not been certified, will that be an issue? I do have a cage with a window net and all the required equipment but, have not had the opportunity to get the certification. I went to a Pittsburg Chrysler Classic a couple of years ago and had a great time! Met a great group of Mopar guys who informed me that I just have to go to Norwalk!
Re: Norwalk Mopar World FinalsII [Re: montessa] #1267127
07/13/12 10:23 PM
07/13/12 10:23 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
No on the engine blanket. As far as the cage cert ---- maybe an issue. What kind of times do you run? If it's in the high 9's you may be ok but if in fairly deep that could be a problem. It is an NHRA track and not all times is the tech extensive but it can be. When I was running in the 9.90 range no problem but now running in the 9.70 range and yea they may check.
And YES you have to make the trip to Norwalk!!!
Russ
Re: Norwalk Mopar World FinalsII [Re: max_maniac] #1267128
07/13/12 11:51 PM
07/13/12 11:51 PM
montessa Offline OP
montessa  Offline OP
Well, Dwayne Porter built a 572 with 440-1 345 Cnc ported heads for my Charger over the winter. Last week I ran a 9.12 at 146 MPH with a 1.25 60 foot times. I missed NHRA tech inspection this spring at my local track. Inspection is only available a few times a season and my car wasn't ready. I guess I'll check with the track to see if I can make arrangements for certification. Norwalk is a 600 mile trip for me and it would really spoil my day if I made the trip and could't run the car!
Re: Norwalk Mopar World FinalsII [Re: montessa] #1267129
07/14/12 01:38 AM
07/14/12 01:38 AM
Ontario,Canada
firefighter3931 Offline
Ontario,Canada
Wow, that's awesome Jim !
Hope you make it out. A bunch of us Canuckians head down every year for the Classic.
Ron
Re: Norwalk Mopar World FinalsII [Re: firefighter3931] #1267130
07/14/12 02:23 PM
07/14/12 02:23 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
Hey Jim
I'm in the same boat as you.
I missed out on cert tech at the "ville" for the Coronet cause it wasn't ready yet. Now that i switched from roots to F2 Procharger it will need it. Let me know if they run one again, I'll go up and meet up with ya.You definetly have to go to Norwalk!!
Kevin
Re: Norwalk Mopar World FinalsII [Re: montessa] #1267131
07/14/12 06:17 PM
07/14/12 06:17 PM
Staten Island N.Y.
Dap Offline
Dap  Offline
Staten Island N.Y.
Dwayne was telling me about customer with a 572 with a set of cnc 345`s. Said it lifts the wheels pretty good..
How much does your charger weigh?
PRH446
10.084 @ 135.21 mph N/A through chambered mufflers,3300lbs. Stock stroke wedge
Re: Norwalk Mopar World FinalsII [Re: Dap] #1267132
07/14/12 11:23 PM
07/14/12 11:23 PM
montessa Offline OP
montessa  Offline OP
Well, I would say It was about 3 feet and wasn't showing any signs of stopping when I lifted. I ended up banging up my oil pan and springing a leak. My feeling on wheelies are if you're going up, you're not going forward. They look great for the spectators but are hard on parts!
Re: Norwalk Mopar World FinalsII [Re: Dap] #1267133
07/14/12 11:27 PM
07/14/12 11:27 PM
montessa Offline OP
montessa  Offline OP
The car weighs about 3660 with me in it. I run an World aluminum block and a light wieght, lift off hood.
Re: Norwalk Mopar World FinalsII [Re: montessa] #1267134
07/15/12 12:06 AM
07/15/12 12:06 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
There is a tech guy that is about 20 min. away from the track. He came out to the track at the same race last year for me and did our car. There is a extra fee that he charges but for me it was well worth it because that is the race that I crashed at . If there is more than one guy maybe that feee can be shared. I will have to dig up his no. or you can contact div 3 for his info. If your car falls into the area of the rules by all means get it done. There could have been issues with my nhra lic if I had not got it done. Dont play with the man!!
JAKES AUTOMOTIVE
Re: Norwalk Mopar World FinalsII [Re: JAKE68] #1267135
07/15/12 12:17 AM
07/15/12 12:17 AM
montessa Offline OP
montessa  Offline OP
Thanks Jake, I have never had the car certified before. I believe that I have met all the NHRA rule requirements such as SFI equipment and driver's licence but, is there anything specific that I should be concerned with?
Re: Norwalk Mopar World FinalsII [Re: montessa] #1267136
07/16/12 02:59 AM
07/16/12 02:59 AM
Central Ohio, USA
Bigbeep Offline
Bigbeep  Offline
Central Ohio, USA
One of Norwalks employees is a nhra tech inspector now. I think his name is Pete. Call the track if you can't get it done close to you. I was at Norwalk this weekend and they were teching cars in the pits. Rumor has it, they may start checking them as you enter the staging lanes and if you are not running a current tag of theirs, back to the pits. That came from the tech inspector Rich, that tagged my car Saturday. As for certification tags, they like seeing them regardless if the car will run in the nines or not because a NHRA employee has already said the cage was safe per the specs.
Oh, the Norwalk race is a must.
Beep
Re: Norwalk Mopar World FinalsII [Re: montessa] #1267137
07/16/12 09:25 AM
07/16/12 09:25 AM
OHIO
THE GLASS MAN Offline
OHIO
If your car is running that far into the 9's then you may want to check into the "MopowerNow" "special rules" for 5/8's wheel studs and wheelie bar requirements. I think Blankenship's "MopowerNow" crew is running that show, aren't they?
Re: Norwalk Mopar World FinalsII [Re: THE GLASS MAN] #1267138
07/16/12 10:46 AM
07/16/12 10:46 AM
Shannonville, Ont
Shannonville, Ont
"Special rules"???
Whats the wheelie bar requirement?
Re: Norwalk Mopar World FinalsII [Re: Blown 68 R/T] #1267139
07/16/12 01:19 PM
07/16/12 01:19 PM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
Norwalk World Finals is known for good track prep & GREAT air!!!
Seams to me the ruling on wheelie bars is, Put it on the back bumper!!!!
Beep, I worked late Sat and could not make it out. I have not seen you out all year. I get tired of being the only Big Back Window Cuda there. How did you do in Ol Blackie?
