Re: Norwalk Mopar World FinalsII
[Re: montessa]
#1267127
07/13/12 10:23 PM
07/13/12 10:23 PM
Posts: 6,353 Aurora, Oh.
max_maniac
Aurora, Oh.
No on the engine blanket. As far as the cage cert ---- maybe an issue. What kind of times do you run? If it's in the high 9's you may be ok but if in fairly deep that could be a problem. It is an NHRA track and not all times is the tech extensive but it can be. When I was running in the 9.90 range no problem but now running in the 9.70 range and yea they may check. And YES you have to make the trip to Norwalk!!! Russ
[Re: montessa]
#1267129
07/14/12 01:38 AM
07/14/12 01:38 AM
Posts: 1,646 Ontario,Canada
firefighter3931
Ontario,Canada
Well, Dwayne Porter built a 572 with 440-1 345 Cnc ported heads for my Charger over the winter. Last week I ran a 9.12 at 146 MPH with a 1.25 60 foot times.
Wow, that's awesome Jim !
Hope you make it out. A bunch of us Canuckians head down every year for the Classic.
Ron
[Re: montessa]
#1267134
07/15/12 12:06 AM
07/15/12 12:06 AM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
There is a tech guy that is about 20 min. away from the track. He came out to the track at the same race last year for me and did our car. There is a extra fee that he charges but for me it was well worth it because that is the race that I crashed at . If there is more than one guy maybe that feee can be shared. I will have to dig up his no. or you can contact div 3 for his info. If your car falls into the area of the rules by all means get it done. There could have been issues with my nhra lic if I had not got it done. Dont play with the man!!
JAKES AUTOMOTIVE
[Re: montessa]
#1267137
07/16/12 09:25 AM
07/16/12 09:25 AM
Posts: 1,186 OHIO
THE GLASS MAN
OHIO
I have been considering a field trip to Norwalk this fall and have a couple of questions. First, do they have the motor blanket requirement on cars running in the nines? Also, My car has not been certified, will that be an issue? I do have a cage with a window net and all the required equipment but, have not had the opportunity to get the certification. I went to a Pittsburg Chrysler Classic a couple of years ago and had a great time! Met a great group of Mopar guys who informed me that I just have to go to Norwalk!
If your car is running that far into the 9's then you may want to check into the "MopowerNow" "special rules" for 5/8's wheel studs and wheelie bar requirements. I think Blankenship's "MopowerNow" crew is running that show, aren't they?
